Leveling a 2014 Chevy Silverado 1500
I want to level/lift my new 2014 1500 but I want it too look like a 2500HD level with no lift. What leveling lift would I need? I'm thinking RC 2.5 or the 3.5
Do the 2.5 inch level and call it a day. Won't be as high as a 2500HD but your front end components will last alot longer.
Edited for suggestion:
If you desire more height add a 1.5 inch Body Lift and would be as high as a 2500HD. Will have no worse suspension wear and tear than the 2.5 inch level alone.
  • 3 weeks later...
I think if you add a 2.5" level you should add to the rear as well. Lifting your front and maintaining some rake will more closely resemble the look you are after, imo. A simple 1.5" front level with spacers or Bilsteins will also do the job nicely! You are after the look. Nobody is going to judge your truck with a tape measure.
