Any Suggestions on Black Running Boards?
  • Replies 53
Looking for some black running boards for my double cab, anyone have some suggestions?
I think this is my favourite topic right now because I just went through this haha.
I get my new GM nerf bars tomorrow.
I was looking at N-Fab and Rough Country before but too many comments on rust showing up.
You beat me to it but I was going to say there's a whole thread on here about Nfab rusting within a month. Apprently the powder coat is super thin.
86" Deezee NXT. I added the pieces at the front to stop rock chips on the front doors.
187AAC92-A0FD-4926-915E-99B922E2A3CA_zps
50C3E094-7D89-4585-ADEF-39DD271977FB_zps
Nothing a coating of Line-X couldn't fix, but then you should just get a different brand like I decided on. The GM ones look like they have a very thick coat.
Tyger brand. Picked them up through Amazon Warehouse Deals for $135. Normally they're $157 so that's not bad either. Had them on for a month and love them. 2b7217ede8845b4582af42b760da3d97.jpg5f8735600f23c318028dcf49bcb3a6ff.jpga50fc6005e5e165fd7f323b0dceb6625.jpg
Sent from my SAMSUNG-SM-N920A using Tapatalk
I have these. https://www.realtruck.com/luverne-grip-step-running-boards/
If you park outside in a winter region, do outdoor activities or just don't want to fall on your a$$ due to snow and ice accumulation on boards these work.
Get the frame mount type not rocker panel mount. :happysad:
I like those but they're pretty pricey. If I want better traction, I'll get some black grip tape and put it on the elevated sections of mine.
Won't help much. Fills with snow, ice. :happysad:
I think it would in my case...would just be a matter of using your foot to wipe off extra snow and expose the grip tape below. I loved in Buffalo NY for most of my life so I can imagine the conditions being any worse elsewhere. Either way, I don't think it's worth the extra few hundred dollars for the metal grate style ones.
I have the magnum RT steps. I love them. Adjustable for how low you want them. I have them sucked up under the body. They are very sturdy. Only thing I have an issue with is the very front where the point is, my tires rub on them at full lock in reverse. I am going to trim the points down to clear the tires. Those are the only 2 pics I have of them.
Go Rhino RB10's
4 mounting points and sits high and tight. I'm 250lbs and they don't flex a bit.
fac633ed86da0d6a4e8c5cad8bcad907.jpgd18362df2c8a04b39dce4e416b498bbe.jpge7ee53d8978bd2758dae3a800c2a36de.jpg94c30d7260502b7efb08dc8bc7af0175.jpge5aee41d9b7a0285cc2e86fa9c0b2eba.jpg
I live in Colorado and spend time outdoors. These are the best for footing.
One fall could cost more than a few hundred dollars IMO. :happysad:
Go Rhino RB10's
I like your Jeep :lol:
    • when it's greyed out that is it's way of telling you that it's downloading the patch in the background. Eventually it will be fully downloaded and then it will prompt you at ignition shut down to run the update. I highly recommend doing the update once you get home and can run it a few times. I've had several issues with updates not going the first time around and I had to retry the update multiple times in my driveway before it was successful.   Some updates are huge and take awhile to download. You can help it by connecting to your home WiFi and keep the truck on service mode for the ignition and keep it alive for awhile on a battery charger too. There are specs it needs to be in for updating such as a full enough battery charge, no running ignition, etc.
    • I am not techy at all but wondered if you have the truck running but sitting still in park as some functions gray out as soon as the truck is moving. I believe in the settings for updates you can choose for it NOT to update and I wonder by chance if maybe that was chosen before and now it won't allow you to chose to press update, I think that is back in the settings menu where it has all the items one wants on or off etc. Also I assume you have a wifi connection and checked that it has some signal strength, not that it would have anything to do with the grayed out updates choice in that case. What I am thinking out loud of here may be be of no value but thought I would suggest it, sometimes it can be the simplest thing that resolves an issue.
