rear brakes
took my winter wheels off this weekend. did my usual brake check and all sliders a working free and easy, but my rear brakes are down to about 30 percent while the fronts are at 70 percent never had a truck that wore the rear brakes faster than the front anyone else find this when they checked their brakes
If your rears are going faster than the fronts then check to see if they are sticking then focus on the fronts not working correctly.
How much millage do you have on it.
    Policeoff01
    Policeoff01
  • Who's Online   3 Members, 0 Anonymous, 719 Guests (See full list)
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
