Well, I found this forum after searching around for grill lighting ideas, and found that y'all have a firearms subforum so I decided to join! I'm more in to shooting than I am trucks, so i figured this would be the best place to say hello. I live in central NC and am in the meat processing industry. Been shooting for about 10 years and competitively for the last 6-7. Mostly in to ARs and the modern stuff, but I have a few of the classics in the safe as well. I try to shoot 2-3 matches a month (USPSA, 2 gun and occasionally 3 guns) from March-October, and generally try to run drills 1-2x per week. Drive a 2016 1500 Silverado WT after finally convincing my companh to buy me one (9 months old with 43,xxx miles on it so far), and also have a 2008 1500 Silverado LT. I also have a 2015 RZR 1000 that we take to WV and some of the riding spots in NC. This seems like a very informative site with a lot of good ideas so I hope to learn some from the truck guys that know a heck of a lot more than me!
Edited by GridlockH8
Also, I like to tinker with stuff, and never liked any of the vehicle mounting solutions I could find on the market, so a couple years back I made something similar for my 2008 and recently made this one for my 2016. Just a piece of scrap stainless sheet we had laying around that I bent and bolted together and mounted under the dash with a Safariland QLS mount system.
Welcome to the Guns, F/A, & Hunting forum. :thumbs:
Don't forget the hunting side of this forum.
I do a little bit of deer hunting too. Our busy season at work is October-January/February, so I don't get out as much as I would like to though.
I like that set up, I've been looking for something to mount in my truck and nothing I've seen I like. Yours is nice.
Tomorrow will never arrive, live life now.
Well just an update...that setup worked well on my 2008, but I guess the plastic under the dash is a lot thicker and secure than the plastic under the dash on my 2016. After hitting a few thousand bumps in this thing, that little pop in clip that holds that section of the dash on has gotten loose and no longer stays in place. It still has a screw to the right of it, but the left side of that plastic panel drops down every time I slide my gun in. I'm going to have to figure out a more secure way to attach that plastic piece where the ash tray normally goes underneath the
  • 6 months later...
Welcome....
Welcome to the forum man.
I tell you I've seen a lot of holster mounts for trucks and they are normally crap. Steel mount with proper locking safariland. Only thing could be better is if was stage 2. Great setup though. Interested to hear if you find a better solution to the mount in your 2016.
  • 5 years later...
I tell you I've seen a lot of holster mounts for trucks and they are normally crap. Steel mount with proper locking safariland.OnlyFnaf thing could be better is if was stage 2. Great setup though. Interested to hear if you find a better solution to the mount in your 2016.
I have never used a hanger. however I don't think it's as bad as you say
Edited by oilumiun12
    • That is a fair point, and I agree that trying to log “everything in the truck” would be the wrong direction.   There are a lot of modules and a lot of traffic. If the product became a full-truck datalogger, the amount of data would get huge very quickly, and most owners would never use it.   I think the first useful version would need to be narrow: - powertrain-side event evidence - selected high-value parameters - communication / voltage / reset events - pre/post event window - short report first, raw log only as backup   One distinction I should make is between active OBD/PID polling and passive bus capture. If you are polling PIDs through OBD, then yes: the more parameters you request, the lower the effective sample rate becomes, and you are adding diagnostic traffic to a vehicle that is already busy running itself. With passive CAN capture, the recorder is not asking all the modules for data. It is listening to traffic that is already on the bus. So it does not consume vehicle bus bandwidth in the same way that a scan tool polling hundreds of PIDs would. But your point still applies in a different way.   Even if passive capture does not add bus traffic, the recorder still has limits: - processing rate - storage rate - timestamp accuracy - decoder workload - event filtering - report size - user attention span   So the answer cannot be “log everything and let the user figure it out.” The product would need to store enough raw evidence to be useful, but only decode, graph, and present the important parts around the event.   A practical report should probably show: - what triggered the capture - how much pre/post data was preserved - which selected parameters changed - how those values compared to baseline - whether the same pattern happened before - whether any voltage, reset, bus-off, lost-message, or communication fault occurred - selected graphs around the event - raw data only as supporting evidence   So I agree with you. More data is not automatically better. The real product is the reduction from raw data into a useful event report.
    • That makes sense, and I agree with most of that.   I think the product would need both: 1. a default powertrain template, so it is useful out of the box; 2. user-selected priority parameters, so the owner or shop can choose what they want to see first.   Different users are going to care about different things. One owner may care about oil pressure and voltage. Another may care about misfire trend, AFM/DFM behavior, or U-codes. A shop may want communication events and repeatability first. Your baseline point is probably the most important one. Raw data is not very useful unless the report can show what normal looked like for that vehicle under similar conditions.   The way I would think about it is: - start with a basic known-good baseline - learn normal behavior for that specific vehicle over time - allow the event to be overlaid against baseline - show whether the event was a one-time spike or a repeatable pattern - provide a simple severity level, but with clear limits on what that severity means   For example, early severity could be something like: - Info: event captured, no obvious abnormal pattern - Watch: value moved outside baseline, but not repeated - Warning: repeatable abnormal pattern under similar conditions - Critical: communication loss, voltage drop, bus-off, reset, or severe repeated event   I would not want the first version to say “replace this part.” That would be overclaiming unless there is repair-confirmed data behind it. It would be more honest to say “this pattern deserves inspection.”   On the OBD port question, I think OBD absolutely has a role. OBD is probably the right place for: - DTCs - freeze frame - VIN - calibration information - normal scan-tool parameters - Mode 6 / enhanced diagnostic data if available The reason I am still looking at an ECM-side recorder is that the failure may happen before anyone connects a scan tool. If the owner plugs in a scanner after the event, the pre-event evidence may already be gone unless the ECU happened to save it. So I do not see this as “OBD versus ECM-side.” I see it more like: - ECM-side recorder: always armed, rolling buffer, event evidence - OBD/DLC companion: DTCs, freeze frame, VIN, calibration, normal scan data - phone/cloud: status, notes, upload, report generation, notifications   I agree that phone connection and push notifications would be useful. I just would not want the phone or cloud connection to be required for capture. The recorder should save the event locally even if the phone is not connected. The phone should help with event marking, download, notes, upload, alerts, and report viewing.   For a default GM V8 event report, would this list make sense? - RPM - calculated load / MAP - throttle position - vehicle speed - gear / torque converter state if available - coolant temperature - oil pressure - oil temperature if available - battery voltage - commanded AFM/DFM state if available - actual AFM/DFM state if available - misfire counters / roughness by cylinder if available - fuel trims - relevant U-codes / communication events - bus-off / lost periodic message / module reset / voltage drop events Which of those would you remove, and what would you add?
    • I went to the county a few years back to dispute my property taxes. To do that I hired an appraiser and a lawyer. The County Assessor wished to argue that the homes in my neighborhood the appraiser used were all 'distressed properties" and not representative of the "Market Average".    My response was," Of the 50 homes in our subdivision 43 of them were "distressed properties" under bank foreclosure and as such "Distressed IS the market". Lawyer about choked on his coffee and handed the Assessor the 'receipts'.    I won that case on the evidence provided by the Lawyer and the Appraiser.    We have the same thing going on here. My statements were based on the GOVERNMENTS NATIONAL DATA and yours on local markets in areas of your interest. They are both correct....   Thing is, this divergence was based on NATIONAL and not on LOCAL. I think you even understand that. But like you said, we are both stubborn and hardheaded.    I do not see any advantage to disengagement.  But that said we can step back to compose ourselves.
    • Trust me I appreciate the comments and concerns. It's what I was looking for to help me evaluate the situation and what I want to do. I have decided to move forward with the BORA hubcentric slip on 3/8" (.375") with the extended lugs nuts. Fedex says they should be here Monday :). Meanwhile, the dealer got the remote start and Patriot spray in bed liner done over the last couple of days. Also, I installed an inline stop/start eliminator today. Starts back up in what whatever mode you shut it off in, so you don't have to hit the button every time you fire up.
