Really hoping someone can help. So I bought the Oracle halo kit and they sent the wrong one. After I opened the headlight housing in the oven. And FYI to anyone who is interested there are two ways to seal the headlights. One is an easy to pull apart glue and the other is a heat activated plastic that you have to almost destroy the housing to get apart. Yes I got the second one in my truck. But anyway I had to ducttape the lights together so I can get to work. The right parts finally arrived and I noticed a few finger print smudges inside the lens. I sprayed the duplicolor wax and grease remover I used to clean parts with all the time and there is some sort of coating inside that turned white and cracked. Ive tried to get it all out and everything I do just makes it worse. Does anyone know where I can buy just the lens? Ive looked and cannot find the lens listed alone. Im sure with people baking the headlights this is not the first time someone has needed just the lens. Please help this has been a huge nightmare and I just want my truck back together.
I seriously doubt it you'll probably have to start from scratch. Just did a quick check, factory stock replacements from the bone yard run ~ $500 per side if you just want to put it back the way it was.
YEAH it is not looking good
Sent from my HTC One A9 using Tapatalk
  • 5 years later...
You can try one of those headlight scratches kit ?? if you get them removed , then tint it.  i used Lamin-x , with good luck.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
