I just bought a 2015 Silverado Z71.LTZ 5.3, the power Sideview mirror is working properly on the passenger side. However, the driver side does not fold in like the passenger side. I tried it both on the door panel and using the key fob with no luck. Is there any other suggestions what I can try? Thank you in advance.
2011 GMC Sierra. Had to do some work under the passenger seat.
Have no idea what those fancy bolts and nuts are called.
Had to take the seat off it's mounts. Somewhat of a commotion.
Front nuts are 15mm or 9/16. 9/16 fits a little better.
Rear bolts are 7/16 and fit good.
Problem with the rear is that they go right through the
body and are exposed to the elements.
Got them off though.
Register a new accountSign in
