I'm looking for a chip
So I got a 2014 Silverado 1500 LT lifted with 35 inch tires. I got a k&n intake and a mbrp cat back exhaust system. What's a good programmer to adjust tire size turn off that v4 mode and give me better shifting.
Thank you in regards
I have blackbear and love it. Been running it for 3ish months and it's a night and day difference from the canned super chips I had before. I have a k&n drop in filter in modified stock box with mit tube, 3rd cat delete and Corsa sport cat back. Plus any mods you do in the future they will retune for your mods. I have Kook's headers and will be going cat less y pipe ordered. All you do is do a data log and send it to them and they will tune for mods. Shifting is smooooth now compared to stock. I've herd good things from diablew as well.
Any exhaust vids or driving clips? That thing should sound like a beast!
Same process with diablew, data log, send to lew, upload to truck, repeat.
You buy chips at the grocery store
You buy a tune from blackbear performance
Not yet, I'll be doing some go pro videos etc when I get the Kook's installed. I've been waiting over 2 months for them to ship from Maryland speed. Getting kind of pi55ed haha
lays-classic.png?sfvrsn=2
