NEED HELP!!! CEL w/ Multiple Codes
Hi everyone I still have my Tahoe but my 2002 Chevy Silverado 1500 pickup 4.8l is currently undrivable!
So my truck has 157k miles and was running extremely well until a I tried starting her up last week and it was fielding really low and stalled. After around 3 tried it finally stood started. While driving I noticed a big loss in power and when in WOT it only goes up to around 2500rpm and won't accelerate and I hear a popping noise. But if I slowly accelerate it can go up to any speed I won't.
NOW.... a few days later it won't even stay started at all. It stays started for a few seconds and just idles really low and rough and just stalls, every time I try starting it. I tried cleaning the MAF sensor and that didn't help at all.
And of course there are check engine light codes. And here's the list of them
P0174 (fuel trim system lean - Bank 2)
P0171 (fuel trim system lean - bank 1)
P0137 (HO2S-12 - Bank 1 Sensor 2 - Circuit Low Imput)
P0300 (multiple cylinder misfire detected)
If anyone has any experience or help to offer it will be highly appreciated!
Wasn't able to check fuel pressure but I did change the fuel filter and it didn't make a difference other than idle at 200rpm for around 10 seconds rather than 3 seconds before it just dies out. I'm starting to think it's my fuel pump but I do hear it prime when in run position
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
