Doug Thorley Headers Installed, LOUD Sierra!!!!
Morning!
My latest review project: Doug Thorley Tri-Y Headers. There is a lot of talk about headers on this forum but I couldn't find much experience with Doug Thorley headers so figured why not check the headers out and provide some feedback on them. Their design intrigued me.
First and foremost these are a different design than the typical 4-1 headers we are all used to and frankly they seem to be the only ones I know of making the 4-2-1. The DTH headers are a 4-2-1 design or tri-y which results in middle of the curve torque and HP gains which in my case on my daily driver (60-80 miles a day for work alone) was much more useful power than top end gains like the 4-1 provide. This concept has been around forever but seems other manus. seem more inclined to the 4-1 design.
Since I was planning to make the video and post here the DTH folks provided a coupon code for me to share in the event you want to take the dive into their products. The code expires July 5th more details in my video.
So my thoughts:
Pros- Completely possible to do this install in your garage but take my advise, GO THROUGH THE WHEEL WELLS. I am not sure why none of the major header manufacturers say anything about this but damn did it make life easier. The overall install was a piece of cake. Everything fit without any modifications needed or special tools. My truck had 50k miles so bolts were relatively easy to remove. The welds and construction seems well made and didn't cause any issues during the install. Seat of the pants test, I think I can feel a little more power during some hard pulls (may just be placebo affect). A tuner will open that open more and solve some of the "cons" issues below..
Cons- 8 hours to install in my garage with a friend helping half way through... These are catless so they are loud and with my SW catback (s-type mufflers), even louder. Half of my commute each day is through town so I throw a bit of echoing noise off the builds and in parking garages. No cats means my exhaust stinks and in rush hour with windows down it does get to you. The final observation is after installing the truck seems to want to go to V4 mode a lot more now (every chance I am at a steady RPM) I suspect because of the CEL being on. A tune is absolutely necessary for headers even more for catless ones so add that into your header budget. Lastly for some reason in V4 mode seems like under 1,500 RPM the truck does vibrate quite a bit more. V4 rides a little rougher than V8 mode even before headers but the headers exacerbated it.
My wallet likes the AFM mode a lot but with LT headers its probably time to say good bye to it.
Anyways enjoy the video. I enjoy making these so hope you guys are finding some value in them. Sounds clips are at the end...
- Waterfowler41
so are you driving around with a CEL?
As with all long Tube header applications the CEL will stay on until the rear O2 sensors can be disabled. Even high flow cats cause CELs.
    • Its coolant disguised as oil.   TSB 20-NA-166 -  20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
    • Good information!  I didn't know about the dementia aspect and asked for a general for my second knee. I'd heard that recovery room time is usually shorter with a general.   The anesthesiologist talked me out of it and I had the spinal.  Inconvenience and/or discomfort is a small price to pay for reduced risk!
    • This is for those over 70 years of age contemplating joint replacement surgery involving general anesthesia. Even some 55 yrs. ago when I took my pharmacology class the dangers of developing dementia in the elderly that had general anesthesia were beginning to be recognized. Over the years there has been some refinement in the cautionary warnings, avoid general anesthesia if possible if you've had close to 10 priors, especially over the age of 70 and/or a family history of dementia. I'm not including the twilight anesthesia induced by propofol often used in cytoscopies or colonscopies. Seriously think about seeing a neurologist and undergo cognitive testing before proceeding if any of those criteria apply to you. Spinal anesthesia may be an option in some cases. I'm in the above camp and although I could use a new right knee, I get fidgety according to a prior orthopedic surgeon when the bone saw spools up or maybe it was the smell of saw blade meeting bone, anyhow I may have one general anesthesia left in me which I will pocket for now and I'm choosing mind over mobility, anyway where did I leave my damn cane!
    • We understand your frustrations with your auto start/stop, fuel gauge and cruise control concerns since your latest update, @LarT-26. You mentioned getting repairs completed, however, have your concerns been resolved? If not, we would like to learn more so we may explore the best path of assistance moving forward alongside your local dealership. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
