anyone tow with the 3.08 gears?
Planning on pulling about 2500 lbs about 450 miles. I know the truck is rated to do so but if you've seen some of my posts on here you know that I hate the 3.08 gears. before I did so though just wondering if anyone on here tows with a truck similar to mine that has the 3.08 gear ratio and has some avg mpg numbers they would share. I assume I'm going to have to lock out 5 and 6 for the trip. truck is a 2010 sierra crew 5.3 afm disabled, will not be running a tune as superchips wants 91 octane for their tow tune and the other tunes are not rated for towing.
When I owned a new 11 1500 Z/71 with the 5.3 & 3.08s I averaged 11-12 pulling a tandem axle trailer loaded with a 72 Chevelle, this was highway driving from Tex. back to Mich. running around 60-65 mph It seemed to struggle a few times in a headwind & slight hills in tow haul mode. Now with my HD & 4:10s that's a whole other story...I think you will be fine with 2,500 lbs out back.
2500 lbs? you could pull that with a big car or small suv. I wouldn't worry too much.
Your mpg is going to depend heavily on what shape your trailer/load is (wind drag) and how fast you are going. If you think you need to do 70+, be prepared to stop often for gas. But if you can drive at 60-65 and reduce the drag of your load (remove ramps, keep it low, etc) it won't be that bad.
+1
The biggest factor is the profile of the trailer. Is it a 2500-lb travel trailer that's a brick, or is it a flatbed trailer with 2500 lbs of bricks/cement? That answer will have a huge impact on your mileage and how it pulls.
thanks for the replies, looks like ill be looking at around 11-12 then. the trailer would be about an 8 ft utility trailer with the drop down gate. also looking into renting a uhaul utility trailer, that way I only have to pull the trailer one way.
