Protecting color matched grill
My 2016 Silverado has a white color matched grill, which I really like the looks of it, but it's a lot of fun trying to keep clean. Bugs of all sizes seems to show up much more than a chrome bumper.
What are some good products that I can use that will not only keep the grill looking it's best but also protect it from bugs and small rocks? I'd like to maintain this look for as long as possible.
I also have a white 2016 Silverado and had Xpel film put on mine to stop the rock chips. More than a year since install and no chips since. Bugs clean off easier too. Check post 7 in this thread if you want to see pics.
http://www.gm-trucks.com/forums/index.php?/topic/188841-are-bug/rock-deflectors-worth-it?&do=findComment&comment=1827741
Good looking trukc Martha! I'll call around today about prices for the Xpel film. Thanks for sharing.
when i had my windows tinted , i had 3m clear flim put on - grill , bumper , 8" on hood .also door still . mine is a black truck
Thanks! Have since removed the chrome door moulding and installed RB10 boards and an UnderCover Ultra Flex.
For reference, my Xpel is 18" back on hood and fenders, grille, bumper, and mirror caps. Cost was $650. Had it done at same time as front window tint (20%, $75).
  • 4 weeks later...
$650 is a good deal for all that xpel coverage, best I've been able to find is about $800
It's expensive for the clear bra, but when you think about it, it's a lot cheaper than having to repaint the pieces.
Xpel Ultimate is the best. My 2015 had it and my 2017 now has it. On this truck I did 18" on hood and fenders, front bumper, headlights, fog lights, A pillars, mirror caps, and grille. I got a deal because I have brought this installer all of our business trucks as well. Cost was 500.00
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 277 Guests (See full list)
