Theft light & AC issues
TMagg27
I bought a used 2014 Silverado Z-71 from a dealership with 35,000 miles. I've had the truck for approx 3 months now with 39,000 miles and have started having issues. The theft light started coming on about a week ago and now my AC doesn't work. Theft light came on until I restarted the truck but restarting it Is only a temporary fix. AC went out with no warning. Drove it to church and worked perfect, came out and no longer working. Since it's just out of warranty I went to my chevrolet dealership to get some input. They said could be 2 culprits...either alternator is going bad or its in the computer. Had alternator tested and it showed good. Can't belive I could be having computer problems at 39,000 miles!! Not even sure if these 2 issues are related but sure seems coincidental. Has anyone encountered this? Hoping for some helpful feedback before I start shelling out a lot of money to the dealership since no warranty. Any help appreciated!!
Someone got rid of that truck for a reason.
Expect the AC problem to be the condenser line. A well known design defect with no proven solution. Parts are on back order for weeks at a time.
Not necessarily. It may have been a lease return.
Many electrical issues here(your alarm) have been traced to bad battery cables. A cheap thing to try first for the alarm problem.
Perhaps an expert can chime in here.
Thanks for the feedback. Already checked the battery cables and they checked out good. Truck wasn't a lease turn-in, was actually a one owner that traded it in. Thinking about contacting the original dealership to request all service records.
How were the cables checked if you don't mind me asking? You can't just run a meter from end to end and expect the resistance value to help. If these things aren't voltage dropped, they'll always test good. I've personally worked on quite a few trucks that were tested by previous technicians at dealerships, i tested them and they all have too much resistance under load. Variables to this resistance come into play too, wire length, temperature, soldering in the crimp. This needs to be checked by someone who actually knows what they are doing. Don't assume that if a tech works at the dealer, that he or she is reputable and good at what they do. You'll be surprised at the amount of jiffy lube guys in there. Being a field engineer for GM, I see this at dealerships spanning multiple states. I work on things that dealers can't fix, I'm the guy that Techline calls to go to the dealer when they've exhausted all means of fixing the vehicle. So, back to your issue. This needs to be handled in the most basic of ways first, and battery cables and supply voltage will most likely be the correction to random electrical problems on a 2014
Justin thats great feedback and yes it was an end to end check. Ill recheck based on your info. Thanks!!
    • probably won't get a response from that user, as they haven't returned to the site since making that one post.  users don't (at least I don't, and I haven't seen any setting which would notify me via say, email) get any notification other than going to this site, and checking if they got a response on their thread...
