11 hours ago, Grumpy Bear said:
Mine stays enabled when oil pressure is under 25 psig and when the deceleration had the injectors shut off in cruise control. Weird. Thanks for the information. So. what tool are you using to pull that from the ECM?
The parameter data I posted is from GM's description and operation of the system in those engines.
  • Replies 34
I got my truck back today and there's no noise.
They replaced the entire exhaust, from the cat back, and everything seems to be working great.
I guess time will tell if it's a permanent fix or not. Best thing was, it was covered by the warranty, so I saved $660.
Glad it worked out!  I went on a little road trip yesterday to make a seasonal visit and tried hard to listen/feel for the AFM to kick in and out.  I failed miserably.  I thought I might have found a Chevy shake at 125 kmh (78 mph) but it went away after a brief time and I couldn't find it again.  Reading this forum makes me much more sensitive to every hiccup!
Yup, you got that last part right. These forums make everyone look for the smallest issue that they normally wouldn't even worry about.
Sent from my LG-H932 using Tapatalk
WOLF!!! WOLF!!! :rolleyes:
