6.2 Badge Opinion
bvernier
Found these badges online and was thinking of adding them on the door just above where.it says Silverado. Would be much the same look as the Duramax Diesel badge.
So my truck is a white redline, picture attached. Silverado on the doors is black on the face of the characters but red along the sides of the characters.
Looking for input on which of the two badges would look better? Black with all red, or black with red and white lettering? Also would you just get two, one for each door, or also get a third and put it on the tailgate above the Silverado badge there?
Thanks1e7c8a541b2d6a7e4bc380d3a9cc0a5e.jpg6b88ea02a339484b82ea36c0ad805cbd.jpge32e956bcb5f2ff552a8c5e040bc0380.jpg
Sent from my A1R using Tapatalk
Neither LOL just my 2 cents.
Haha fair enough
It's not a vortec....
I'm willing to sound like an idiot... Do they not refer to the new direct injection motors as vortec anymore?
Haha fair enough
Ecotec3.
I put 6.2 on my last truck. Lots of people noticed that. Even the dealer asked what package that was(really).
Neither and as stated it's not a vortec.
8fe67d009581493ba0e810336937fa97.jpgbetter imo
2017 Chevy Silverado LTZ Z71 6.2L
4.5" Zone
22x10 AF Grips
33x12.5 Nitto Ridge Grapplers
Instagram @wildchevys
4.5" Zone
22x10 AF Grips
Nice cover
Sent from my SM-G955U using Tapatalk
Nice cover
thanks
4.5" Zone
22x10 AF Grips
What would be a good color to do on this cover if I've got a black truck?
black or the silver it comes in
4.5" Zone
22x10 AF Grips
I chose the old school location :)
Me too but I decided to do something a little different (got the idea from my 79 L82 Corvette). Yours looks slick btw!
