A/C on it's way out
Well today I noticed that the A/C seemed a bit weak. After a 2hr commute home through Tampa traffic, it's on its way out. Took forever to cool off, it did OK after 30 minutes but was struggling to keep up. Truck is 3yrs and 15 days old to the day. 69,XXX miles. That's an early failure in my book. I did add the AC bracket around 36k that GM recommends as a fixer. Dumb question, but any chance to get warranty coverage on this being there is a tech bulletin issued to address this issue?
i would definitely try it. I had two condensers replaced on my 14 model, but had the extended warranty. Hope I don't have the same problem with my 17 model.
Yea, won't be covetable under warranty. Best chance you have is the dealer eating the repair. Unless they try to goodwill the repair. On my 16, my a/c lines are good and no condenser issues yet. I'm at 21K
Some have had luck getting GM to cover the repair, or pay a portion of the repair. Im at 59K and have been monitoring my system closely expecting a condensor leak too. Good luck.
I had the condensor done under warranty on my '15. They had 8 online ahead of me at the dealer. Condensor was on backorder. If I were out of pocket I would be buying aftermarket with a lifetime warranty which I saw offered by a place in south Florida. Its a known issue at the dealer I assume there is a TSB. One option for you while you are waiting is to charge it up, I got almost a month out of that before it went warm again.
When mine went out it was noticeable by looking through the grill at the condenser on the drivers side. You can see the expansion tank is held to the condenser by two points that are braised. The upper braise point was where it was leaking and you could see where oil had made tracks on the condenser running down. I was able to add Freon and it would only last about two days before I had to add again. My dealer told me they had received 9 aftermarket condenser the Friday before I got there on Monday and only had 3 left.
I bought the truck with the extended warranty until 100k miles. I still have another 12k to go.
  • 4 weeks later...
Update. It was the condenser, surprise surprise. GM worked with me on the price being I'm the OG owner and it broke 3 weeks after 3yrs. New condenser, back in business.
Great to hear they worked with you.
-S
I find if your a gentlemen and state your reasonable case nicely, it usually has good results. I mean its a known defect in their product that you paid good money for, and you just went out of warranty. Good to hear common sense and decency came into play. Good luck.
On a side note, I just traded into a 2017 from a 2015. Exact same truck. They completey redesigned the A/C lines. I don't know about the condenser?
I agree seamus2154. Be reasonable. no more 1st year trucks for me.... i need to buy last year models. Get the discount because the new models are on the lot and forgo all the headaches. win win.
Yes Sir! I have always found first year anything with GM is no good. One exception, the 2006 Zo6! But technically that was a second year car first year motor! LOL
Alot of very good deals on 2017's right now. I bought the 2014 also as it sucked me in as such a big leap and improvement over the previous trucks. Then they had some great offer which I didnt get hurt getting out of it into a 2015.
Good luck!!
    appletrav
    appletrav
  • Who's Online   5 Members, 0 Anonymous, 348 Guests (See full list)
