Cadillac Rear View Camera Mirror
Now that it is available in a few models, including the Escalade, has anybody thought about retrofitting these into our trucks? I would love to integrate the camera on the rear window and maybe somehow split it with real time mirror view and a video recorder.
  • Replies 36
get @pgamboa on this project. he needs something to do. ;)
LMAO! I read this post last night and wondered who would tag me! [emoji23]. I’ve got front park assist sensors to get added today, but will be looking at this and a use case.
i'll buy your auto dimming mirror, once you're done.
You'll be upgrading to Cadillac one. You won't want a cheap one after that. ;)
Where is the camera located? Is it separate from the back up camera that sits above the license plate?
I picked up my auto dimming mirror for under 15 on eBay.
If you find another for 15 send me the link. Cheapest I've found is 40 so far
Neat idea. I don't understand folks who use the backup camera only and not their mirrors or turn their head.
This will make that argument harder. :)
-S
It's interesting that you can watch behind while driving also.
This looks doable for Phil. ;)
It’s just a Dual switchable camera right? How hard can it be? [emoji23]. Anyone got part #s?
That's the spirit!
:D
-S
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 277 Guests (See full list)
