Leaf spring noise
RussW
I see lots of complaints of leaf spring noise on 2014 & newer Silverado’s. Mine seem to be popping when in reverse. Of course the dealer can’t/won’t hear it. I’ve re-torqued all bolts & cleaned/lubed the leafs. Anybody ever try leaf spring clamps to keep the leafs aligned?
My Sierra (2016) has about 21000 on it and it has made a similar noise sounding like its the springs shifting at very low speed from day one. Dealer never found anything either (but they haven't done so good on couple of electronic error fails either..)
Can't tell you how many times I've checked the rear spare to see if it was loose... :-0) and looked around under there.
Several weeks ago, while rotating tires and under truck, I noticed passenger side shock housing being scraped by the upper shock boot, to the point of cutting into the lower tube metal from the single rivet (about 1.5 inch by 4 inch long, outside facing). Dealer ordered me new shock and when it gets replaced, I will report if its the "source". Check yours around the fill rivet (I assume  that's what it is) and see if there is any scrap marks?
Mine has 25,000, I bought it with 19,000 on it. I only seem to hear it when backing out of my driveway and crossing the curb. Noise seems to come from right rear but leaf spring on left rear seems to be making the noise. Sounds like something loose underneath. Right rear Rancho shock had grease all over the bottom tube but dealer said it was ok. I see lots of complaints about the Rancho shocks & was thinking about ordering Bilsteins but don’t want to spend the $ only to still have the problem. Let me know how you make out. Thanks
BTW-My noise is also more notable in reverse.
Is what you call "grease" just oil mixed with road grime? I ask because pickup shocks (i) are not "greased", and (ii)  are not supposed to leak ANY oil, so that is a sign that the shocks are failing. Doesn't matter if it was defect, wear, or abuse, it is a SEALED system.  Sealed means nothing goes in, nothing goes out... Just like a house's air conditioner is a sealed system, so it is NOT supposed to loose refrigerant-if it does, you have a leak and you will pay the repairman every year until they fix the leak.. Why compare to air conditioner? Well, most modern shocks are also gas filled, so if oil is leaking, the gas definitely beat it out...
Two things: Visit http://www.gorancho.com/warranty-guarantee/
First, some Rancho shocks have lifetime or extended warranties. See if yours are still covered independent of the dealership's biased word.
Second, if it was my truck, I'd try hard to make them replace under warranty as latent defect since a due diligence inspection on their part WOULD have caught that grime, and they know better, as shocks leaking are on the State Police's checklist for many states that do vehicle inspections (for a reason). From living in northern Maine and time on dirt logging roads, I have found front tires as more susceptible to wear from bad shocks, but rears will show uneven wear as well, especially if soft tire. I am guessing it is because lots of off road/dirt roads makes the length of travel of shock tube get maxed out a lot.  Doesn't' need to be off road, even, as I had GM installed Rancho shocks on Silverado that did only a bit of woods work and ended up with couple of shocks and tires getting replaced by dealer, at their nickel, for causing improper tire wear/damage. Good luck!
leafs need to slide.. since 1492. :)
I added strong u-bolts to my 21  yr old truck, with hellwig helpers.
it needs to make a seat every morning with a clack.
cab mounts start next for you young ones.. just needs time and a new day.
Thanks. It is probably road dirt sticking to leaking oil. I’ve wiped it off twice in 3 weeks just to see if it comes back. My son-in-law has a 2015 also & installed Rancho Quicklift struts on the front & within a week had to replace one as it was leaking. I may have a bad shock but I can hold onto the leaf spring & rock the truck & can feel it popping. I’m going to replace the rear shocks one way or another & I’m going to take it to a suspension/specialty shop & see what they have to say, and then MAYBE go back to the dealer & see what they’ll do. I’m the 3rd owner of a 2015 so there maybe something there that somebody else was unhappy with. Good thing it’s still under factory warranty. The saga continues....
Took it to a specialty suspension shop who said they “couldn’t duplicate the problem”, and suggested I haggle it out with the dealer since it’s still under warranty. Guess I’ll have to wait until something obvious breaks or fails. I’m gonna try new shocks and see what happens.
update on the rear noise and rear shock rubbing on boot... passenger rear shock came in, they replaced it, and so far, a bit over a week & about 1100 miles into the replacement, I have not heard the low speed/backup noise that I've complained about since mile 1... and the new shock, so far, does not have any wear marks on it.
BTW-Dealer groused that they were doing me a favor to replace the unit under warranty since it was not "leaking" and the shock tube metal being worn about 10% through "did not constitute a defect".  So I just told them thanks and chalk it up to good customer relations, especially since they still didn't have a fix for my constant "service rear vision system" issues.
    • I've been eyeing an upgrade to my tonneau cover for a bit now.  Intrigued by the BAK MX4 EZ-Lift with the torsion spring and went for the upgrade.  Thoughts and musings during unpacking, install and a few days of usage.   Once my order went into Realtruck, it took about 4 days to ship.  Unfortunately, FedEx Ground destroyed the box and contents and it was unusable upon receipt.  To Realtruck's credit, one email with pictures and an RMA was sent to me to send the first one back, and another unit was shipped out.  It arrived 3 days later, unscathed.   I opened the box and it looked like every other BAK MX4.   Biggest differences are the rails and retaining clamps, and of course the spring attached to the cover itself.     NOTE - if you are upgrading from a MX4 to the EZ-Lift, you will have to replace the rails.  The EZ-Lift rails have a notch cut in them to allow the new style retaining clamps to fit properly.  The new retaining clamps also have 2 knobs/carriage bolts and there are two tracks underneath the front panel. The strap clips are mildly different (more like the Undercover Flex clamps) in that the screws go in from the underside.  Personally I prefer these over the BAK clamps that use the nutserts that are a nuisance to install.  The remainder of the parts in the box (drain tubes, rail clamps, and bumper pads) are standard issue BAK.     I did not replace my front bed seal at the time because it seemed to be in decent shape.   BAK recommends shims on the GM trucks unless you place the clamps on the flanges about 1/3 of the way in from both the front and rear of the bed.  I shimmed the front and the middle, and initially placed the clamps equidistant.  This also turned out to be a mistake, because when I set the cover in place, the new style retaining clamps wouldn't clear the front clamp.   New style clamp inserted in the track:     And the issue which occurred because the front rail clamp was too far forward:     Once I removed the shim from the front of the bed, and slid the clamp back to the front flange, everything cleared fine.     The cover set on the rails without issue and I installed the strap clamps.  After I completed my adjustments, I pulled the pin to activate the torsion spring.  Mistake #3 on my part.  PULL THE PIN AS THE VERY VERY VERY LAST STEP!  The reason is, once you pull the pin, the torsion spring is activated.  If you have to loosen the front clamps and adjust the cover, the front panel will - by virtue of the spring, refuse to lay down.  The only way to get it to lay down so you can reinstall and tighten the clamps is to fully open the panel against the back of the cab, which will then allow the front panel of the cover to lay down and be tightened.  Not a big deal unless you haven't installed the foam pads yet (typically the last step) because minus the foam pads, you will need to place something between the frame of the cover and the back window so it doesn't get scratched.  The next time I install one I will install the foam pads before I pull the pin and activate the spring.   After using it for a few days:   The spring assist is great.  You literally can open it with one hand.  My shoulders aren't getting any younger and this was part of my motivation to swap out. The second panel latches and unlatches itself as you open and close the cover.  Neat in concept, however it took me a minute to get used to closing the cover and not hearing the "latching" sound that would tell me it was locked in place. The paddle handles are a huge upgrade and I wouldn't be surprised to see them become the standard across the Realtruck line.  They effectively eliminate the concern that a thief could coat hanger the cover open and get to the contents in the bed. I'm not sure why the very front panel on my cover has a different finish from the other 3 panels.  I have a request into Realtruck to find out if mine was not manufactured properly or if it was by design.   All in all I'm pleased.  Same level of protection, looks good, keeps stuff mostly dry (they all leak around the tailgate) and easy to install.
    • Same here, first I bought a few filters to get me going right after I bought my truck to do some short distance initial oil changes, then realized I could buy a case lot for less as they drop the price if filters or trans oil etc is bought by the un opened case lot as well as the discount for buying the vehicle there. So I have filters for a while but its good to know going forward, knowing to expect it to be a different part number and looking filter at the dealer and not be confused over it and think they are handing me the wrong part.
    • Saw Inglewood was in the National New last night for hail. Allot of hail. front end loader level hail. 😱
