2014 Silverado I purchased in late August with 61,000 miles have drove it 6,000 miles with NO issues till last night. Started up the truck, put into gear and started rolling when the steering assist disable alert came on for a split second then went out (truck has had current recall performed). Drove about 5 miles up the road with out any other issues to get gas. Pulling out of the gas station the headlights and dash lights flashed and the HVAC went to A/C mode on, didn’t think much about it just turned off the A/C and proceeded to drive back home. On the way home in traffic I noticed as I applied the brakes my headlights and dash lights would flash. As I turned on my turn signal to pull into my driveway the whole vehicle died!!! Engine shit off and it was just as if you climbed into a vehicle with absolutely no battery at all everything was dead. Fought the steering into the driveway, put it in neutral turned the key off then to crank, started up just like nothing ever happened. The display said theft deterrent active, 2 keys programmed, then something about the drivers window being down?!?!? Living across the street from where I bought this I went straight over and told them there was an “issue” I explained everything that happened and when they hooked up the code reader the only code was for the right headlight circuit. I left it there for them to look at because I felt unsafe driving it. They called me today wanting to know how often this had happened and i explained i had just bought it and it was the first time for me. They said ok thanks for the info, a few hours later they called and said that the only abnormality they could find was that the negative battery cable was showing excessive resistance. I told them that it has to be fixed and they said ok we will order the cable and then they told me that after the cable $100 plus labor and then the diagnostics that my bill would be around $430. I said $430 and it would be fixed? They replied that they couldn’t guarantee that because they wasn’t 100% sure that was/is the problem. Has anyone else experienced anything like this??
My 2014 was at 53k same kind of issues it was the battery. Hope that helps
Edited by John1493
Spelling
Do both battery cables. Have the battery load tested and make sure it’s state of health isn’t now. Should fix you up.
  • 4 years later...
Has anyone with these electrical issues tried looking at this connection ? Drop your plastic skid plate thingy and it's right there. It comes right from the battery, (both negative and positive) and goes to the ECM. I just did mine today. It had a mild to heavy white frosting on both the blades. I took emery cloth and cleaned them, then applied dielectric grease. Have to wait and see what happens.
  • 4 weeks later...
On 10/24/2017 at 9:08 PM, JoeWilliams said:
2014 Silverado I purchased in late August with 61,000 miles have drove it 6,000 miles with NO issues till last night. Started up the truck, put into gear and started rolling when the steering assist disable alert came on for a split second then went out (truck has had current recall performed). Drove about 5 miles up the road with out any other issues to get gas. Pulling out of the gas station the headlights and dash lights flashed and the HVAC went to A/C mode on, didn’t think much about it just turned off the A/C and proceeded to drive back home. On the way home in traffic I noticed as I applied the brakes my headlights and dash lights would flash. As I turned on my turn signal to pull into my driveway the whole vehicle died!!! Engine ****** off and it was just as if you climbed into a vehicle with absolutely no battery at all everything was dead. Fought the steering into the driveway, put it in neutral turned the key off then to crank, started up just like nothing ever happened. The display said theft deterrent active, 2 keys programmed, then something about the drivers window being down?!?!? Living across the street from where I bought this I went straight over and told them there was an “issue” I explained everything that happened and when they hooked up the code reader the only code was for the right headlight circuit. I left it there for them to look at because I felt unsafe driving it. They called me today wanting to know how often this had happened and i explained i had just bought it and it was the first time for me. They said ok thanks for the info, a few hours later they called and said that the only abnormality they could find was that the negative battery cable was showing excessive resistance. I told them that it has to be fixed and they said ok we will order the cable and then they told me that after the cable $100 plus labor and then the diagnostics that my bill would be around $430. I said $430 and it would be fixed? They replied that they couldn’t guarantee that because they wasn’t 100% sure that was/is the problem. Has anyone else experienced anything like this??
I had this problem when temperatures reached 90 degrees and a/c was cranking while making a left turn. Truck shut off. Truck was under warranty. Brought it to dealer 3 times they could not repeat the issue. On the3rd time , days after the warranty expired, they said they found the problem and billed me for it. They said it was a loose ground wire under the radio speaker left top of dash board. Problem went away for 5 years now seems like its coming back again
Almost 4 weeks now since the 2 repairs I did, (pictured above and negative ground on frame) the truck is running very good so far. My problem was one or the other or both. I had all the same problems in previous posts.
My buddies 05 Colorado has the same issue. Driving down the road and it just dies. Climb under the front end and smack the crossmember with a hammer and it runs again. Has to be that connection in the pics above.
All good advice. Battery, Battery cables and google G218 Ground point which is the ne under the dash speaker.
Our 2014's were quite glitchy. They are not designed for non mechanically inclined people 🙂
Yotaman
    • I have A 2020 1500 5.3 8 speed. LTZ. Transmission problems since 60,000 miles. Started when I go to store in morning to get my morning coffee before work leave truck running get back in put it in drive/ rev no movement step on gas a little slams into gear. Put in neutral step on gas little shake then put in gear and gose.  Shut truck off start .. ok now at stop light stop truck after a few seconds feel a little kick if that doesn’t happen stuck in 3/4 gear shut truck off wait few seconds and start usually ok again. If you down shift manually ok as long as you get into 1st before stop. If not it kicks . I WANT A NEW TRANSMISSION. Now I want a new truck it just hit 80,000 IDK IF ILL BUY CHEVY CAUSE THEY STILL HAVE THE PROBLEM AND REFUSE TO RECALL . Oh I’ve changed the fluid and filter 3 times now. And yes used mobile 1 not ac/delco cause it’s not meeting the requirements that mobile is did use ac/delco filter
    • Of course refrain from political debate but I myself have very dismal hope for what is all going on up here every where we turn so I nodded my head when I saw this joke.
    • I'm looking at carpal tunnel surgery on my left hand and lumbar fusion.
    • While waiting for parts I have been working on installing the AC compressor, new accumulator, and orifice tube. Also changed out the high side ball valve (original). The orifice tube that was in there wasn't too bad. Slightly dirty, a little bit of junk, but not blocked. Glad I changed it out.   The accumulator, which should have been a 5 minute job, may have just burned $50. Put some PAG in it, wrote the date and mileage on the side, fresh o-rings and gooey'd up the threads and rings with Nylog. Got everything connected and snugged and was going to vacuum down the system, and....   My manifold gauge won't fit on the port. It's not an R12 service port. It LOOKS like an R134 service port but the diameter is a hair too large. There's a sticker on the accumulator that says it's designed to be used with R12 and R134a systems only. So it's not R1234yf. Even if I reduced the diameter slightly with a file, the shoulder on the port is too large so the quick-connect valve won't lock on. I'm stumped. It's going back, and 50/50 on if they'll give me a refund.   Also, I did a fuel pressure test.... Key on, the gauge spikes to about 60psi and quickly bleeds off, like 2psi per second. The fuel isn't going into the plenum, no smell, starts fine, so I'm guessing there's a bad check valve in the pump and the fuel is just draining back into the tank. oh, hell. But, it shouldn't be a problem, pump primes just fine and the truck starts right up. It just means I can't really ever use fuel pressure to verify a leak at the injector or intake.
    • Got this yesterday out of nowhere. Truck is a 25',6.6 gasser with 8k miles.  Only semi anomaly is that the truck had been sitting, uncranked for 6 days. Elec Stability Control showed immediately upon cranking, not while driving. No drivability issues, just the message. Battery didn't seem to be weak when cranking over.  I drove it, killed it, let it sit a few hrs with no avail.  Truck is 100% stock. No damage.
