Dead battery?
silverWS6
My 14 Silverado had 79,000 on it and still going when i traded a few months ago .
When I traded for one of my 2014's my 2001 f250 had the original battery. It had a insulation wrap around it.  Had good headlights and radio too!
Older trucks didn't have all the parasitic drains of computers, ECM, BCM, memory for radio, daytime running lights coming on while cranking engine, etc. etc. They are a constant drain on battery and if driven regularly it'll stay up but let it sit a bit longer or colder temps, anything to put more draw on battery at startup and click click click.
17 hours ago, Donstar said:
Battery in my wife's 2007  Toyota  never been replaced,  knock on wood!  I was going to replace it awhile back as a precaution but the service tech said the current battery charges fine and not to waste my money!
Is the tech now looking for a new job?
I just dropped the car off half an hour ago for an oil change and to check the battery.  I revived a phone call 30 seconds ago saying the battery now needs replacement!  (Car hasn't been started for a week but started fine this morning)  Not bad for an 11 year old Panasonic car battery!
  • 1 year later...
Similar problem in my 2015 Yukon Denali.  Drove home yesterday, 120 miles.  did use wipers and heater due to rain, cold.  Truck ran fine.  Came home, unpacked, seats went back up, hatch worked, nothing left on.  Came out 3 hours later to go someplace, and NOTHING.  doors wouldn't unlock, no lights came on, completely dead.  Voltage check on battery said 4 volts.  Charged it overnight, and voltage holding @ 12.8 Volts.  Alternator is working--voltage jumps to 14 volts plus when engine running.  It started up and ran like nothing had ever happened.  I don't know the age of the battery, because we bought it "pre-owned" 6 months ago, but the battery is a Bosch, and I don't think those were OEM.  seems like everything is OK, but now I'm afraid to trust it?  Anybody had similar issues where it wasn't an old battery?
On 12/14/2017 at 5:49 AM, beetle said:
Batteries can fail without warning. I change mine every 4 years no matter how well it spins over. .............mileage means nothing.
Me to.
Have done this for years.
Not worth the hassle to have a vehicle not start when needed or change a battery in cold weather.
Changing the battery in my 2012 is not easy.
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
    • No, we trade them like pokeman cards.
    • It would be sold as a "kit", lights + auth/programming code.   You can resell the code to someone else, if they just buy the lights, either new or used, and they can then use the code to get them to work on their truck.
    • Apologies in advance, this is a long post, there's a lot to explain.   A friend had a 2010 Avalanche with a 5.3 (LMG) that blew the head gaskets (amount other problems). He gave me a donor motor out of a 2007 suburban (LC9). I got it all installed, and everything hooked up. Went to go start it, and it stumbled a bit at first and died a couple times, but after trying a few times it sounded like it was running very well. Went out to go get some coolant, and came back the next day.    Upon trying to start it, the truck will crank and fire normally and the RPMs will raise to around 1,200 or 1,500, sounding great, and then the RPMs will decrease and it will just die. Repeat that a dozen or two dozen times, and eventually it will fire and idle beautifully. As soon as you touch the throttle, it will start misfiring and sound like absolute trash. When you let off the throttle it will come down and hunt around shaking and misfiring like crazy. A message will come up on the dash saying reduced engine power.    It is throwing codes for a map sensor circuit voltage High, as well as MAF sensor low frequency. With key on engine off, the map sensor reads about 4.8 volts on the vout pin, which the PCM interprets as about 17.8 PSI, contrasted to the barometer which my scan tool tells me reads about 13.5 PSI. However, once the engine starts and is idling this reading drops to about 5-6 PSI at a stable idle, and varies significantly when the engine is misfiring/ hunting like I said before. I should note that I used the intake and MAP sensor from the LC9 engine. I changed the connector on the 2010 harness to The 2007 connector. The pinouts for the sensors were printed right on the top, and I triple-checked that I put the correct wire into the correct place.   On the other hand, the MAF sensor reads consistently 0.0 g/s regardless of State. I have pulled my hair out trying to figure out this last detail. I have tried three different sensors, (all of which should be good, one of which was new), I have verified all the wiring from the sensor going back to the PCM, and have verified that the readings at the PCM are the same readings as at the sensor itself. The intake air temperature sensor is also functioning as normal. I verified all the voltages and grounds etc, and everything is as it should be. I don't have an oscilloscope to verify, but I probed with my multimeter (Klein mm720) on frequency Mode, and it reads that on initial cranking, the maf is producing between 3000 and 7000 HZ, and as soon as the engine fires that falls off to below, 1000, and if the engine continues to run, it will produce somewhat erratic readings between 5 and 100-200 HZ. It does increase notably when the engine is revved despite the misfirings. As I said before, I have verified all of the wires going to the PCM, and I have tried multiple known good sensors. I've tested all the pins and voltages from the sensor and verified them against the manual that they are what they should be. I tested all the wiring for both ohms and voltage drop, and everything tested fine. Like I said I tested at the sensor as well as right at the PCM, everything checked out.   The only other thing of note at least I think is the fact that the engine originally in the truck had VVT, but the engine I put in, the lc9, does not have VVT. I modified the cam sensor plug to work. I reference the wiring diagrams and double-checked that I modified the harness correctly to adapt it. There is obviously a code for the VVT solenoid, but I don't think that's the cause of my problems, and this friend will probably have the PCM sent off to tune out the codes at some point.   I'm writing this for my bed so I don't recall the exact codes, but I'll update the post tomorrow morning with the exact codes. And ideas or feedback much appreciated.
