New bolts after bed liner
I just had the spray in bed liner installed. The truck looks great, my issue is that the bolts that held the old  plastic liner (tailgate panel) is now too long. (looks weird) what did you guys do ? is there a part number for shorter bolts ?
My Line-X dealer had bought over 1000 new Stainless Steel 'screws' for 2014+ GM truck access panels and used these after spraying - just the right length.  I don't know if GM has any. If your spray dealer won't replace your new screws with the correct length, you may need to buy your own - just take one from your access panel when you go shopping so you get the correct type and length.
Sounds like a discussion you could have with the people that put in your new liner.  It should be part of the process.
i got mine from lowes.
Hillman 4.2m x 20mm Hex Washer-Head Zinc-Plated Hardened Steel Metric Body Bolt
Item # 138162 Model # 881172
Checked my agreement, no mention of replacing stock bolts or any other. Spray in liner and warranty??
Had the same problem with my Titan when I bought it. Brought one of the stock bolts with me and matched it up to some bolts at Home Depot. A little shot of black spray paint and you'd never know they didn't come on the truck from the factory.
I am sure they would not be required to replace the screws but strikes me as reasonable thing to do after such a modification.  The company that provided your plastic tailgate liner had to supply longer screws.  Your spray-in requires stock length screws which should have been provided, imo.  I definitely would not expect or accept protruding screw heads after paying for a spray-in liner.
In my case, I had sold my factory plastic bed liner beforehand, so I knew going in that the bolts from the factory were going to be too long.  So I went up to lowes and got replacements prior to line-x.  just had to go to 2 different lowes to get all matching bolts.
Plastic liner came from dealer, I kind of disagree. People that spray in liners, spray in liners. Don't seem to make much since to carry hundreds of bolts for the many different truck types ?? maybe it's just me. Now if it where the Chevy dealer that dealt with my particular vehicle maybe
    • 287,500 Mile Service   8/13/2026   Reset Fuel Trims   Since the work done in the previous post there was a good improvement in response in all areas except right after a fill up where the LTFT would go -20%+ for about four miles while the STFT was near neutral. Before the work they both went very negative for a few miles after a fill up but act normal thereafter.    We did a systems check of the vapor recovery system for functionality and ability to hold a vacuum. That checked out fine. But this doesn't mean the charcoal canister is dead in the water. Testing that is next up. For now the reset of the fuel trims.    I intentionally shorted the fill exactly two gallons to eliminate any chance of filling the canister. On start up the trims were behaving normally until I got up and rolling where the LTFT went -10 / -11%% but the short was + 2 to 0%. Within a mile the the STFT offset the LTFT and by 2 miles they were neutral. HUGE improvement but still not hunky-dory.    I'll watch them for a few days. Perhaps another tank where I will fill completely to 'first click' and compare. Meanwhile on the hunt for a new canister and I'll toss another purge value at it for good measure. Pending the outcome of the canister test that is. Progress of any kind is welcome.    Fuel economy improvement with bringing hole #3 back to the living was a noticeable bump to the positive. Even on the few miles I drove after the refill I already see another bump up by the trims reset.     She's purring like a kitten with a warm bowl of milk.
    • Yeah, shame I can’t really get that filter easily anymore. Running a PureOne. Your fave!    TAN would be neat to see. Confirmation I ran it too long probably. 🤣
    • My son and I both bought new trucks in 2017. Both of us immediately put Truck Covers USA American Roll Covers on our trucks. My son still has his truck and it never sees the inside of a garage. We live in Alabama, so not much snow. My truck was my daily driver and was in the garage when I wasn't driving it or at work. No issues with either cover even after almost 9 years. About a year ago I sold my truck to my brother and bought a 2025 Silverado 2500. The second thing that I put on that truck was a new Truck Covers USA cover. They are very well made and have a very positive locking system. I looked at a Retrax and my concern was the way that the cover locked to the rail. BTW, the first thing I put on the new truck was step bars. Those new trucks are high!
    • The Allison 10 speed torque converter doesn't "lock up" like the previous transmissions. It has 4 operational modes; open, slip, transition from open to slip; transition from slip to open. I have an Edge CTS3 monitor and I monitor transmission torque converter slip. Step on the gas and you get a little slip. Take your foot off the gas and you get a little negative slip. I have not found a way to display the torque converter mode beyond that. My Edge CTS3 also displays something that our trucks should already display, the current gear. I also monitor throttle body position and engine load. If I see the engine load getting too high, I'll manually drop a gear.
    • Nice result. Your filter is working well  I'd have like to have seen the acid number for this sample. Curious type that I am.
