Stock Height Measurement
Bushmaster
Just bought a 2017 2500HD Denali. The dealer cranked up the torsion bars and installed after market wheels and tires. I just wanted to know if someone could provide the measurements from the middle of the wheel to the fender on a stock height 2500HD. I'm just curious about how much they lifted the front of the truck. thanks for the help.
On ‎12‎/‎24‎/‎2017 at 8:32 AM, 4wdriver said:
What is your measurement now?
Haven't measured it yet, but I know that it's cranked to high. the upper A-arms are less than an 1/8" away from the brackets. I want to bring it back down closer to stock. I just need a reference point. Anyone have a measurement? Thanks
Don’t know where my notes are but I think it was around 24-25 inches from the center hub stock.
Crank the bars back down and see if it rubs. Mine came riding on the bump stops from the factory. Mine where also high on the passenger side by quite a bit. About 4 turns of the adjuster bolts got it off the bumpstops, raised it maybe and inch.
