On 2/18/2019 at 12:37 AM, wepiii said:
I was having all of these issues but found a fix that has cured all of them for me... unfortunately, the fix is unpairing the Bluetooth connection. If I have Bluetooth paired and CarPlay, it works like 50% of the time. Once I umpired bluetooth and just used CarPlay, I’ve had 0 issues with CarPlay.
I’m having all of these car play connection issues on my 2019. Thanks for this suggestion, I’m going to try it.
17 Silverado iPhone 8+ same issue my work around works 50%. Continuously tap projection icon rapidly 6 or 7 times it should continue to make ticking sound through the speakers then connect
  • 7 months later...
I've had the same problem with my last 3 Acadias.  I update the iOS software, so the phone is ruled out.  Also eliminated, using a new USB to Lightning cable (authentic Apple).  However, the GM software or firmware has never been updated.  Only solution I've found other than convincing the dealership to FW the unit is to turn off the vehicle for about 2 minutes (and open the door to turn off Retained Accessory Power and wait for interior delayed lights to go off), then restart the car.
Edited by Mobile Electronics Tech
typo
  • 2 years later...
Not sure if anyone on here still has issues or not. I have a 2016 Sierra 1500 Denali, and have had issues with getting my CarPlay to work since buying my truck. I recently went into the vehicle settings and there was a tab that said AppleCarplay and it was set to On. Another tab says add/edit devices. I clicked on that tab and the previous owner had 2 phones on there. I deleted them both and restarted my phone. When I plugged back in my phone there is a button in the bottom right that said pair or add device that went from dim to lit up. I clicked it and it let me add my phone to CarPlay and now it works. I thought I was gonna have to get an new HMI module. Even took it to the dealer and they said I had the current infotainment update for my truck. Hope this helps anyone out there.
  • 8 months later...
2017 Chevy Silverado 1500 Apple Carplay issues have reached my breaking point. The system turns itself on/off without notice. When on, it switches radio stations arbitrarily and even switches modes from radio to other functions. GPS will not work, and the touch screen is disabled for most of the functions. I am at a loss at how this technology makes my life simplified. I am ready to buy foreign on my next purchase to replace this otherwise great truck. UGH!
  • 7 months later...
On 1/14/2018 at 2:13 PM, steve76t said:
HI All,
I have a 2017 GMC Sierra 1500 Denali & have issues at time with Apple Carplay.  Sometimes it connects just fine while other times is doesn't.  When having connection issues, the carplay icon on the home screen will usually be there, but doesn't do anything when you touch it.  When having issues, text or call notifications don't appear on the infotainment screen but it'll still play messages or make calls when you press the voice command button on the steering wheel.
Could this be an issue with the phone or the infotainment system? "Sometimes if I turn my phone off & restart it before getting into the truck carplay will work fine.  However, it's a  50/50 chance that it'll connect again the next time I try.
Suggestions???
Hey, new to this forum, did you get any answers to this problem?
    ncleg
    ncleg
  • Who's Online   4 Members, 0 Anonymous, 843 Guests (See full list)
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
    • Yes your absolutely right, I been looking at the 4 inch BDS one and it acutely states you can use the stock 20’s just not the 17’s or 18’s, I also didn’t realize that with my 275/60r20 stock wheels I’m already running 33 inch diameter wheel setup lol so I can just run my stock wheels and tires atleast to start.
    • I would expect that to be lift-kit dependent.  If the kit has interference issues w stock wheels, then the kit/manufacturer should indicate that somewhere.
