Electrical issues
So i have this issue, all started at the same time and i can't figure out where the issue is, no power to the fuel pump, when i turn on headlights theres no lights on the dash and ac controls. the power locks and windows stopped working as well. I have a 92 GMC c1500
All the fuses are good, any idea where the ground would be for those, i have checked the ones i could find but it's obvious I am missing something simple somewhere in the dash.
Im not entirely sure with this generation.  If no one on here can help I would try a dedicated GMT400 forum.  It seems this forum is aimed more towards newer trucks.
  • 3 weeks later...
You may have lost power or ground involving the interior fuse panel. Could be a fusible link near battery or the under hood fuse box. I'd check to see if you've got +voltage going to the inside fuse box.
