Personally, I've had good experiences with Craftsman and Husqvarna lawn tractors, they're reliable and well-priced. The Husqvarna LGT2654 you mentioned sounds like a solid choice, with 26 HP and a price tag under $2k, it ticks all the boxes. That being said, you should also check out John Deere, Kubota and MTD.
Edited by agollin
My mower is still going now at 8 years old as mentioned when this thread was started. As is the one this one replaced at 22 years old now. There was a little mishap 2 years ago. I ran over a stick it took out the little cooling fan the cools the transmission. I didn’t think much about it until it quit moving very good and got noisy. So I rinsed it with the garden hose and finished. Now I just break it in thirds. I may just get this one refurbished it was the last one I could find with a handle instead of a ft hydrostatic drive. I usually wear out the deck mowing damp in the morning. I don’t do dust. I probably should give it an oil change this year its second. I got it in 2015. It’s still clean on the stick. Another benefit of mowing wet. I’ll think on that.
Lots of good points and I agree the newer lawn tractors are cheap and won't last too long. I came across this 1992 Diesel powered Kubota a few years ago and swapped it for a Golf Cart my kids were no longer riding. It has a 3 cylinder 18 hp engine. I use it as a backup for my 20-year-old Exmark ZTR and for yard work. If you can find on in good shape, they are a great value as when new they were like 7K but the Zero Turn has devalued them due to their overall grass cutting speed and performance. But if looking for a lawn tractor these are hard to beat.....and I know old post but springtime and people may be interested in the yearly Grass cutting debates
XB 2002
  • Thanks 1
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
