LED headlights
On 4/6/2018 at 1:06 PM, catpartsman said:
The HID is a more focused light beam where the LEDs I had weren’t. The projector housing scattered the light more with the LEDs than the HID or Halogens. The halogens weren’t bright enough for me so I went with The retrofit source kit.
What color bulbs did you end up getting and did the match the small LED lights in the headlight?
I went with 5500’s. I’d say they are pretty close. Let me see about getting a pic later today for you.
It's not so much as the HID is more focused as the bulbs produce light on all sides, as it is the lens that they are in aren't ment for the intensity.
Sent from my SAMSUNG-SM-G935A using Tapatalk
I'm currently running the opt7 flux X in the high and low beams in my 14 silvy with LTZ projectors. I'm pleased with they're output. They work great and if I need more when there isn't any oncoming traffic I hit the highs. If that's not enough while on the ole back roads I hit the rigid fogs. If your running projectors then you should be fine as they focus the light in a better used pattern rather than scattering it in a reflector housing. Hope this helps.
Here's the difference in the lows and highs. 4a6e3a725333d5a46bdd800bf5dfefa2.jpga0489bfe857180a14a67add8f6dfa508.jpg
On 4/6/2018 at 1:05 PM, catpartsman said:
High and low is one bulb in my Sierra.
I believe OP stated he had a Silverado, which does not use one bulb for low/high beam.
Sierra use 9012 bulb, and a shutter to operate high beams.  Try thrretrofitsource.com for the morrimoto HID kit, plug and play.  You can get LED fog light assemblies or just bulbs.  Stuff is good quality.  there is a sticky on lighting that will tell you all about it.
    • No doubt, I definitely agree with you. However, considering the 6.2 and 3.0 have been catastrophically failing with very little miles, I figured I would put trouble free. I’m at 18,4xx and still not a single issue.
    • It’s never dry here but it gets hot. My 4 vehicles I keep at home drive an 18 mile loop. One 6 days a week. Two about 3 days each and one once a month. Only one goes on trips about 4 times a year 1000 to 2000 miles each time. One 26 years old gets driven once a month for 22 years. One 14 years old goes 6 days a week. The other two are recent at 2 and 4 years. All are performing normal no extra service other than that would be half of recommended or severe service in the maintenance manual. No extra water or steam out the exhaust or premature plug wear. I would consider an 18 mile loop would be enough. So apparently once a month at 18 miles for 22 years has kept the collector car running well. About 45 minutes a month.
    • It is working as designed.  NHT and non NHT trucks have the same exact transmission cooling setup.  NHT just gets a larger radiator.     The transmission cooler loop on these is as follows.     -Transmission out goes into an oil to water heat exchanger (item #1 in the first illustration below).  This exchanger has engine coolant opposite the transmission fluid and uses engine coolant to warm and then regulate the transmission fluid temperature when its in the operating window.   - From the cooler it goes to a thermal bypass valve (item #11 in the 2nd illustration below).  If the ATF has not reached the temp to open the bypass (194F), it loops back.   - When it reaches 194F, the thermostat opens and ATF then flows out to the oil to air auxiliary cooler (item #17 in the 2nd illustration) at the front of the truck.  From there it goes back to the transmission.     Your only fix would be to swap for the PPE thermal bypass delete block which will open the loop to the aux cooler all the time.  It will STILL run warm, probably 170-200F, but that's as low as you'll get it as its still flowing through the oil to water exchanger.
    • Most say the oil temperature needs to above the boiling point of water to rid it of moisture and long enough to dry it. Many think that is about a hour at 212 F or more. Those people have never line dried cloths in a Midwest winter. Leave a pan of water sitting on the counter and eventually it all evaporates. So heat drives the time it takes. Water in oil under 175 F, the Nitration initiation temperature, is a minimum then for temperature and samples I've done that use Karl Fisher method say about a hour (in a healthy well tuned motor) over 175 F will dry it to under 800 ppm. Low enough to not be much of a factor. Motors with weak rings will take longer and the colder the air temperature the longer it takes.   On a cold motor there is also the condensation temperature. Blowby gases that contain moisture are subject to that cold cylinder wall, like sweat on a glass of ice tea. But also subject to the Law of Partial Pressures. Wear studies by GM and the DOD  indicate wear is a real issue below 85 F and a concern to 140 F but doesn't become a minimal factor until about 160 F. You know this intuitively when you see water vapor exit the exhaust pipe until the system gets above the dew point. It isn't magic, it's physics and it fascinates me. I know you didn't ask but....I over share sometimes. 😉    You keep the Camaro's high and tight.
    • Move further away.   Benefit of living out - none of our cars get short cycled, plenty of warm up time.   Curious how much time/temperature it takes to drive moisture/condensation out of the engine?
