Nice!
hows the 6.2 8 speed compared to your 5.3 6 speed?
Supposedly the 6.2 really wakes up after 10k miles. That’s internet rumor anyway.
Congrats on the new truck these things are awesome. Every time I go out to fire up my 2017 Denali up I admire the styling. I am pretty mad at GM right now but not mad enough to get one of those ugly Ford's that I have been looking at. To me the Ford trucks just do not have the style of a GM  Denali. aka "Work Of Art"
That’s a beautiful truck.   To those that don’t know, they’d say I have one just like it.  To those of us reading this, we know better.    Only sorta close.   Nice.
The 6.2 has way more jump, no throttle hesitation like my old one. As to "waking up" after 10 k miles, well that's gonna take a while. My 2014 only had less than 20k on it when I traded it in, lol
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
