2016 Silverado 2500 S and B Intake
So just put this in yesterday. So far I really like it. Fitment was perfect, quality was awesome, and it really cleaned up under the hood. Now I didn't buy it thinking I'd get insane performance, just strictly as a helper to go along with my exhaust and future custom tune. With that said, I was very impressed and surprised the performance bump. Throttle response is definitely up as you lay into the throttle as well as a little bump in MPG. Did a 100 miles yesterday with a mix of 70/30 city/highway. Seeing a bump of about 1. 5 mpg. I'll have to do a few hundred miles and hand calculate it in the coming weeks, but very happy thus far. Lastly, the sound. Idle, easy acceleration, and cruising are dead quiet. Once you get do some harder pulls into the 3k range the engine really comes alive and really complements my Corsa exhaust. So for 300 bucks I'd say it was definitely worth it and I extremely happy. I'll keep you guys posted. I know it's hard finding performance accessories for the late model 6.0s.
Side note: 2015 and 2016 and late models have different intake setups. So make sure if you go to order one that you specify you model year.
Thanks for posting. I see so many mixed reviews on CAI's for the 2500. Nice to see one that is realistic and not just hating on them for the sake of hating.
In to follow for future updates. Thanks for sharing.
  • 2 months later...
Which Corsa? I was looking at some - not sure what I'd like to do as I don't want it to be too loud, but a good rumble is nice!
Thanks for CAI info!
  • 2 months later...
What Corsa exhaust do you have?
I wanted to get one for my truck but they do not list any fitment for the 2015 and up 2500-3500 6.0 trucks.
I just received my S&B for my 2015.  Getting a tune done after thanksgiving.  Nice to see someone else review a product I am yet waiting to install.  Right now with deer season and work, it'll be a few days before I get it installed.
  • 8 months later...
    zibzer2
    zibzer2
  • Who's Online   5 Members, 0 Anonymous, 846 Guests (See full list)
