2016 Silverado , warped rotors?
Have a 2016 Silverado, with only 10k miles . Seems like my rotors are warped already. Is this common?
Only drive to and from work mostly and moderate stop and go, No towing or any heavy loads.
So, do i get my stock rotors resurfaced or say screw it and get the Powerstop brake kit upgrade, with new Pads and Slotted rotors?
I wouldn't turn the rotors, I would get a new set.  Drilled/slotted rotors aren't really better, except that they look cool.  I've had good luck with Raybestos rotors, no slots, just the Advanced Technology ones.
Thanks for the tip to get the Raybestos rotors . Would I have to get new brake pads as well? The current ones seem like new...
I guess I'll start with swapping the front rotors then go from there.
  • 3 weeks later...
I just replaced rotors and pads on mine, It seemed as both inside break pads on the front were dragging almost non-stop causing the brakes to wear uneven and trash rotors from the heat. I've seen some people simply grind the edges (barely) so they slide a little better in the slots. Be careful not to take to much as you will get a loud rattling sound from the pads bouncing. Hope this helps to prevent it from happening again soon.
Might be too late, but I would have gotten new pads for sure.  There is a reason your rotors warped and it could be because the pads were not seating right and, with the new rotors or after the brake job, could do the same thing.  You want new pads and you want to bed them by doing a few 30-5mph brakes and then a few hard 60-5mph brakes.  5mph is reference, as long as you don't stop, it should be fine.  It's just a way to make sure they are braking on the entire surface and eliminate any high spots without damaging anything.
Slotted rotors are intended to vent gasses that build up under the pad due to heat during use.  Modern pads though, have eliminated much of the gas build up problems.  Slotted, or cross drilled rotors are really more for looks these days, but if you really want them, be prepared to replace your pads more often.  The slot edges, even if rounded, will chew your pads quicker.  Don't even bother with cross drilled rotors.  They are prone to cracking around the holes.  They're even illegal on many racing circuits these days because of that.
The reasons for having slots and holes dates a ways back before modern technology fixed the shortcomings that drilling and slotting was designed to fix.
And yes, if you get new rotors, get new pads.
    • I have a 2000 Silverado 1500 LS, whenever I put it into reverse and also in drive it clunks, the truck also feels sluggish when driving. Any advice/ideas ?
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
