Trailer issue -2015 chevy 1500 w/ trailer brake
Truck randomly "check trailer wiring" followed immediately by "trailer connected"
I replaced the trailer side plug first and it made it worse, then I replaced the truck side trailer plug.
Hooked it up drove 50ft it threw the dash code. Drove 10 miles to my house. Nothing. Put my rzr on it, threw the message 10 times in a mile. Then it stopped, drove 40 miles absolutely nothing...?
Trailer is an older 2002 rice tandem axle trailer.
Any ideas?
Sent from my SM-G955U using Tapatalk
Thanks, I will try the emery cloth. But they are both brand new plugs.
My message is never about brakes, just wiring
Update:
Went under the trailer and wiggled and moved every single wire, it didnt trip this message.
Then when I left with trailer attached BAM it started saying "check trailer wiring... trailer connected".
I have learned its ONLY the brake that messes up. With my lights turned "on" the lights never go away when the truck says that message. Sometimes it will say check trailer wiring and the trailer brake wont work for a minute or two then it will kick back in. BUT while this is happening, the lights still work.
I'm about to replace the trailer battery for electric brakes. It's pretty old.
  • 3 months later...
Update:
My truck does this exact same thing. My dad removed the brake battery for some reason but on his truck, 2001 2500 Chevy, he doesn’t have any issues. Did the trailer battery fix your issue?
I had the same issue.   Could not figure out for the life of me.   2018 1500... I checked all the wiring.   Under the truck the triller wiring comes for a hub that also has the brakes, LED bed lights etc... I both the cable and swapped it just incase (dealer could never duplicate issue). I then bought a new battery for trailer brakes system (not because fo the issue but because it was older and going on a long trip through mountains).   I have not had the issue again.  THIS MAKES ZERO SENSE.  But... it is what it is.   I have yet to have the issue again (going on about 3 months).   Take it for what it is worth.
I just dealt with this issue. I changed to the GM recommended trailer end plug which did not fix the problem. Ended up checking all grounds on the trailer. there was a ground terminal block that was corroded. Changed that and cut wires back to clean copper. Also where the main ground wire attached to the trailer frame, removed and cleaned the ground block and frame to bare metal and through bolted it back onto the frame, then cut back ground wire to fresh clean copper. Problem solved for me! Hope this helps.  Also could be a shorted to ground trailer brake wire somewhere, often times the wire that is fed through the axle grounds out inside.
This is happening to me in my 2016 Silverado 2500HD duramax/Allison while towing a fifth wheel 35ft coach. In June a dexter axle  dealer checked the trailer wiring and replace one of the wires that travels through the axle as it was shorting out also re-did all the connections. In August was leaving the campground on the beach and had to use 4-wheel drive to get out, shortly thereafter I started getting the "trailer connected" followed by "Check Trailer Wiring" messages. Changed the 7-way cable and connector from trailer and the truck, no change. At local dealer service manager connected truck to another camper and did not get messages and breaks worked. Continued to get message as soon as I connect trailer. went to a different dealer and they said the "trailer control module" was defective and replaced it. Time to move the trailer again, connected and got the same messages. They will come and go, stay on and off for 15 to 20min the will go away until i apply breaks again, then they are back on and off for awhile.
I have never actually lost the breaks on the trailer. This last move I did notice that as I applied breaks the trailer breaking was not proportional to the pressure applied. Some times it was a smooth stop and sone times it has a full slam stop. I can find nothing wrong on the trailer, although I am unable to remove the tires to check electric magnet wiring, I just do not have the strength anymore to lift the tires.
Any help would be greatly appreciated. Oh every trailer repair dealer or mobile repair service are broke over 2 months ahead.
    • Most thermostatically controlled ATF systems use a 'wax' pill just like the one in your water thermostat. They work on the expansion volume of the wax and the pill is constructed in such a way as to limit the travel to remain within that range. This means it has an opening temperature often called the 'cracking temperature' and a fully open temperature. For whatever reason oil is designated by it's fully open temperature and water by it's cracking temperature.    Between the two it the "Regulating Temperature" The entire range is about 20 F from closed to open. In your example the lower limit, opening point of 145 F then has a fully open temp of 165 F and a throttling temperature of 155 F.    Thing is, the throttling temperature needs two things to work properly. Enough system load high enough to reach the minimum and a heat sink (cooler/exchanger) large enough to prevent any load applied from exceeding the fully open temperature.    If your system exceeds the fully open temperature it is screaming MORE COOLER.    Here is the silly part of the whole thermostat system where the oil is cooled/heated by the radiator. Nothing is flowing to that system until the oil temperature reaches the cracking temperature unless it is equipped with a minimum flow bypass orifice or a bypass built into the seating surface of the plunger. That system meant to get it up to temp quicker isn't doing a thing until WORK drives if from ambient to cracking temp. One a cold winter day, like zero F, it may never get hotter than about 110 F. Sometimes not even that.    People forget or are young enough to not know that until this millennia transmissions were cooled by the radiator cold tank alone and without a thermostat at all.  In the 50's they weren't even cooled. OEMs learn everything the hard way.    When an OEM tells you the trans "Works best" between 175 F and 220 F it means works best for THEM. The transmission thermostat is fuel play. If you watch you trans temps like I do you will learn that it may take a hundred miles if you are not towing and not driving more than say 55-60 mph on a zero F day to even reach 120 F and it might sit there all day if it's colder. Yet if functions perfectly over about 100 F. It may need to get a bit warmer for the fuel and spark maps to go without an multiplier.    Worry more about too hot. Use a cooler large enough to put that thermostat in range.
    • Around 2008 if memory serves they took sulfur out. That was when diesel went up.
    • Question for you Grumpy, why is diesel so much more than gasoline? Seems to me that it may be slightly a little less refined than gas and it doesn't have 10% alcohol which presumably lowers the price of gas
    • Thanks, so being a different beast altogether, anyone know what the "optimal" temp is for the 10L80/90 for proper shifting?
    • How many years have I pointed out every point in that link to the folks here and been avalanched with criticisms and outright hostilities at times? I ran counter to even the great CUSTOMBOSS and Lake Speed Jr and the half dozen experts on YouTube and in the final.....GM, Physics (Stribeck) backs that Grumpy old Bear.    Honestly, I never said a thing engineering hadn't studied silly and laid in concrete during WWII. But I'm old, the information is old and yet, the Laws of Physics are eternal.    Okay there is one exception. I vehemently disagree with their use of the word 'tolerances' when what it meant is "clearance".   The clearance is the distance between two objects. The tolerance is the degree of acceptable variation permitted in that clearance. I.E., piston to bore clearance is 0.004" with a tolerance of +/- .0002" so the clearance is in specification if it lies between 0.0038" and 0.0042". Cutting that 'tolerance in half has ZERO impact on lubrication requirements. Makes for more difficulty in manufacturing.  But a tighter clearance 'MAY'. Depends on finish. Anyway....   It's one of those statements made by people to make themselves look smarter than they are to convince people who are as un-enlighten as they seem to manipulate their behaviors. But hey, the blind leading the blind puts them both in the pit.
