Hello Guys,
I just traded in my 2012 Chevy 1500 Z71 and got a brand new 2018 Chevy 1500 Z71 with stock 18 inch wheels. Im sure its been asked but ive tried searching the forum, google, custom offsets etc. and cant seem to find the answer. Im having a ready lift 2.25 leveling kit installed and want to get  the largest tire I can get. I found plenty of info on the stock 20’s and 22’s and aftermarket 18’s just not the stock. So is anyone running 33x12.50 on the stock 18’s? If so please tell me what brand tire too. Any help would be appreciated.
Edited by luckyshotbrooks
Hello Guys,
Just bought the Bilstein 5100s and leveled my z71. I went with 33x12.5 Nitto Ridge Grapplers with stock 18s and I have 0 rubbing issues with no trimming needed.a862ebf2882c565acc73a26436410c3a.heic5405d8d350252a82e041c6193401c26a.heic
keep in mind upping tire size on a stock truck will throw the speedo off if you have a high gear ratio
I was looking at the Nitto Trail Grapplers so I’m wondering if the more agreasisive thread would cause me an issue. Do you have plenty of room or is it just enough? I had the 275/70r18 grapplers on my 2012 with no issue but they were nearly as wide. Can you post a picture of the side? Curious how far they stuck out. Also what size lift do you get with those  Bilsteins? Thank you for your help.
Yeah I had 275/70r18 grapplers on my last Chevy so I know it will be off a couple. Eventually I’ll get a tuner and fix it. Thank you.
I have a 3inch MOTOFAB level with 295/70/18 Nitto Ridge Grapplers with 1/4 wheel spacers and they barely rub the upper control arms.
Ya I don’t think the more aggressive tread would be a significant enough difference to cause you any issues, and I feel like there is plenty of room but I haven’t actually gotten down there and looked how close it is at full tilt. The bilsteins give you 0-2” so at full extension it’s a perfect level . I’ll take some pictures when I get back home of the tires at full tilt so hopefully you can see if there is enough room and I will also take some from a side view showing how much they stick out.
Here are the pictures I promised you!
The tires really don’t stick out at all.
210a60314e5d726d2bf69312f4f1a67b.heic
Full tilt front of the tire plenty of rooma7743ef898f12d5bfdd6a19f89bb416a.heic
Full tilt back of the tire: there is actually more room then the picture shows, just under an inch, just hard to get a good angle for the picture 801a220a710926b5315d48c4e5913471.heic
I appreciate the help and pictures. I really thought they would have sticked out a little further. Thats a good thing though. I eventually want to get new wheels but I just can’t get them at this moment. Tires are more of I priority at the moment. Just want to make sure what I buy will work now and in the future. Thanks again.
Its just thetire not the wheel.  Changing the qheel it would stick out more
  • 1 month later...
They dont rub the upper control arm?? Thats surprising
Sent from my SM-G950W using Tapatalk
  • 4 weeks later...
Ya that’s what I was wondering. I have the ReadyLift 2.25 leveling kit and on their website it says up to a 33x11.50 tire. It also says a half inch spacer may be needed if using stock wheels. I went ahead and bought 275/70/r18 Trail Grapplers since I knew for sure they would fit but I’m really wishing I would have got the 33x12.50.
2.25 billet aluminum ready lift here with 285/60/20’s = 34’s on a +1 offset with trimming on liner. The exact same size with BFG KO2’s barely rubbed. Apparently, KO2’s are cut smaller diameter.
I know they fit with an aftermarket wheel but there is hardly any info with the stock 18 inch wheels. Im
just not ready to pull the trigger on aftermarket wheels at the moment. Readylift’s website says if using the stock wheel I can’t go wider than a 11.50 without using a spacer. I’m wondering if it has to do with the new UCA’s that come with the kit. I might just got by Discount Tire and try out a 33x12.50 tire and find out myself.
My neighbors new Chevy truck fit the 275/60/20 just fine before he did the level then rubbing started. Apparently, new stamped UCA’s are in late 15’s through-8’s versus machined aluminum ones before. Once he did level he had rubbing on full turn lock then bought new wheels +18 which fixed everything keeping the 275/60/20
    • I have a 2018 Silverado Custom with 156k on the odometer. In the last month I've replaced the plugs, wires and the driver side engine mount. My wife just returned from a trip of about 1500 miles and told me the brakes are making a grinding noise when applied. I drove it and looked it over and this is what I found with the driver's side rear rotor.   I'm going to order new pads and check about having the rotor resurfaced. Hopefully this is easier than the last 2 jobs.   Peace
    • Any update if the new valve cover help with the oil consumption?  I have a 2014 GMC sierra and my truck is consuming a lot of oil so I’m wondering if replacing the driver side valve cover will stop some of the oil consumption. Thanks
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
