2015 Silverado 1500 z71 Exterior Recommendations
I’ve gotta be honest....I love the way it looks as is. How about performance upgrades since it already looks great?
Preciate that man. What kind of performance upgrades would you look in to?
  • Replies 33
I would leave it as is and only buy gas. That truck is gorgeous as is. Every artist has to know when to stop.
I always tell myself I’ll stop after the next little thing lol
I always love making minor aesthetic adjustments to my truck, but have recently run out of ideas. What would you guys suggest, I’m open to anything? I recently bought some new headlights so I’m waiting to install those and also got some recovery hooks to replace where I had a bull bar, but other than that I’m looking for some other opinions on what to do. If you guys owned this truck what would you change? Thanks for the input! 9dafd4e0c972ad2ecd576ca350840aab.heicd7c0fc817453072577207d6854b92ec7.heic49143df5da396e40de0c110fbdde6e78.heic
Love the blacked out headlights!! I was thinking of doing that to mine but was a little worried about it killing the brightness of the headlights. How much does it affect it and did you just tint them?
I’m sure you’ve done all the basics. I was just thinking there isn’t a single thing I’d touch on the exterior, so the next step might be engine tuning or power upgrades.  Or, perhaps I’d save for my next new Silverado if you like the upcoming model.   What motor do you have?
Yeah it’s just tint that I bought off amazon that was precut to be an exact fit. It does dim it down a little, but it’s not terrible. To me it was worth it for how much it improved the look. I actually just bought some headlights that have a black housing so those are about to come off!
It’s the 5.3 L V8
Ditto on the debadge
Which led pos do you have in the fogs?
My rigid fogs arrived yesterday & the spots are supposed to be here tomorrow.
I’ve got the rough country pods. I really like having the extra lights, I hardly ever used my fog lights before.
are you using the rigid pod bracket for your fogs? I was wanting to do the same on my 2015. Looks really clean though, like other stated id definitely go for an exhaust upgrade!
I actually just bolted the lights directly to the fog light housing and didn’t even need the bracket. I had read online that the pods I bought weren’t compatible with a bracket so I just went ahead bolted them down without one.
Yeah, the factory fogs are functionally worthless.
I actually like the stock tinted headlights.I would tint the fogs to match and paint the grille inserts matte to finish off the front look.Side profile with those wheels looks dope but I personally like a little more rim and a little less tire when everything is black to break things up
Beautiful truck!
Thanks man. Definitely want new exhaust, just don’t really know where to start
Borla exhaust, go on their website and listen to all their exhausts. I personally do not like loud exhaust systems so I prefer the Touring Exhaust
    Greg3160
    Greg3160
  • Who's Online   2 Members, 0 Anonymous, 436 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
