OEM 2014+ DQS power folding towing mirrors
Like new excellent condition OEM DQS gm tow mirrors with all options.. however they do not have the temp sensor for diesel application. These were removed from my 2018 Silverado ltz 1500 with less than 1000 miles. I installed regular size dl3 mirrors. I didn't have to do anything different with the wire harness so i believe if you have a truck with the dl3 mirrors and want to upgrade to these tow mirrors you should be the same .  Will fit 2014-2018 1500 and 2500 non diesel trucks trucks.
However I would check with  pgamboa to be sure on your application.
Asking 950.
Located in Spring Run, PA 17262
IMG_20180723_190547.thumb.jpg.185808353c358968cbca650a5ca6580c.jpgIMG_20180723_190516.thumb.jpg.fdfadf55563c4c2b27638ccc69aed3e9.jpg
These have blind spot light? Not sure if that was even an option then...
