I doubt as there has been some RCSB Trail Boss mules running some sand dunes.
I can confirm that the 6ft6in box is body tagged 03-43-53 so 03 = regular cab, 43 = crew cab 53 = double cab.
Regular cab is last to launch too, I assume due to the fact that Ft.Wayne is handling crew cab and double cab launch production.  Once Silao starts spitting out crew cab T1 trucks (they are still doing 2018 crew cab), the regular cab will ramp up at Ft.Wayne.
Given how K2 was, I'd expect WT and LT for sure, and we might get Custom, Custom TB, RST and LT TB.
Edited by newdude
God I hope you are right! Thanks
Well GM Canada just messaged me back saying that reg cabs will be with 8ft boxes only. They have been wrong before in there messages to me. I hope they are wrong again!
24 minutes ago, Likarok said:
On page one of your attached guild I see code 107 with a 6'6" option under the reg cab column. Am I reading it right?
Yeppers.
I can't wait to see the double cabs!  Anyone know when they are hitting the lots?  I've only seen those photos of the blue model from the car shows.
Sierra Elevation Edition Double Cab:
I swear that looks like a freaking Tundra!
I currently own a GMC, but the 2019 GMC would not be in my Garage! :sick:
Silverado looks so much better in the front, and tail lights.
These GMC tail lights remind me of the 2005-2012 Colorado/Canyon style.
    whenindoubtuseahammer
  • Who's Online   3 Members, 0 Anonymous, 281 Guests (See full list)
    • Enjoy the new truck, it’s a beauty. I’m glad you’re keeping the OBS, I love those old trucks.
    • With large equipment or deep mud it is more of a use the higher gear to avoid spinning tires, getting stuck because of spinning tires and doing damage to your machine. The idea is if you run out of torque before you spin tires you can still downshift for more torque. If you are just spinning your tires in the lowest available gear you are stuck and things break.   Automatic transmissions, traction control and electronic transfer cases change the calculation a little as you the driver have less control over each piece.
