Window Auto Up Feature
Is it possible he's mistaken?
Well, poop.
Unfortunately, yes, I’m mistaken. I just went out and tried it for myself... and was immediately disappointed to discover auto up does not work from the keyfob as I had originally posted. Im sorry for the error and confusion it might have caused.
However... my intuition tells me there’s a certain economy of scale involved in sharing computer development between platforms. I bet there are flags in the bcm (might as well be voodoo tho) that governs how the windows behave, be it Yukon, Tahoe, Sierra, or Silverado.
M
1 hour ago, BuCrew said:
Here's a good video that explains why manufacturers don't do it.
And it's Brian Cooley so it's entertaining.
Nice detail, totally would have paid an extra $200 if I could have bought it that way. With all the other options, would be nice to have.
Oh well, same with the other festures like adaptive cruise, blind spot, auto wipers and keyless access I wish I had in the truck if there isn’t anything I can do cost effectively I will deal with it. Every car has something you have to give up it seems unless you want to spend $80k. For every feature it doesn’t have I find a new one that it does, so a little balance I guess.
I got an extra switch to play with just in case it was available but not setup for use. I was able to make the double up click on the passenger button, but no auto up.
I am going to look at the circuit board next. Still interested to see if any Tahoes or Yukons are auto up on the pass side. I see mixed posts.
Geez... $6 a window.. $18 for a 4 door.  Just add it to the msrp and you wouldn't even notice it. I suspect the that it's part of pushing folks to a higher trim level.
We were just talking at lunch about it. Charge $100 for it and I would have paid. As much as I use the windows the convenience/getting my hands back on the wheel is nice with auto up/down.
    CaptainDad
    CaptainDad
  • Who's Online   7 Members, 0 Anonymous, 566 Guests (See full list)
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
