So after a lot of research it seems like 265/70r18 might be the tallest P rated tire I can fit on a stock height Silverado with my factory 18 inch wheels. It's probably the size I'm gonna go with once the stock goodyears wear out to gain a tad more ground clearance and get a slightly more aggressive A/T tire without lifting/leveling my truck and ruining the comfortable stock ride it currently has. I'm wondering if anyone has any pics of this size tire on their stock height truck?
Or you could go with a 285/65 18" if you want.  I don't think I have ever seen a 265/70 mainly because most go for looks over function and that size will be tall and skinny looking.  The 285/65 will give you the same height (32.6") but a wider foot print and will look much better on the truck and will still fit on your stock rims.
well that's an odd tire size, and there are not any trucks that come from the factory with that setup. Most come 265/65/R18.
265/70/R18 is only a 1" taller tire overall. Meaning that it is only going to "lift" the truck 1/2". Almost going to be unnoticeable. I doubt that too many people even go with that option because it is not really a significant increase to warrant getting new tires.
I don't know how odd that size is.  I was thinking of that size as well.  It gives just a bit more tire size without needing a level.  I agree though that not many would pull off usable tires to change to this size.  I will be waiting until my oe tires are worn out.  The 285/65 option does sound interesting as well, but I would think the 265 width might be better in rain and slushy snow.
My thoughts exactly. I'm gonna wait until the stock wranglers wear out, then probably switch sizes when that happens.
Tall narrow tires are great for deep snow. I had 265/70/18s on my ‘08 and I’ll most likely get a set before winter for the stock wheels for my ‘16.
  • Thanks 1
I put 275/70R18 under my stock Silverado. 3565052ed2dcc4e131206f52efd5055d.jpg
Sent from my SM-G950U using Tapatalk
  • 9 months later...
does it rub? is it 4wd
Edited by zikronix
It does not rub. It is a 4X4 Z71 CC STD Bed.
2 minutes ago, JRL1164 said:
It dows not rub. It is a 4X4 Z71 CC STD Bed.
i think the 4x4  z71 has a higher stock lift and suspension profile than the standard trucks. Thanks for the info!
Last tire purchase I struggled with the same dilemma.   There is nothing to gain by going with a higher aspect except a perceived better look.  Nobody else will notice or care.   The slightly larger and heavier tire will not improve performance, economy or function.  In the end, I decided to go stock.  However, my situation at the time was different and expenses required a higher level of justification!  If you decide to go with slightly bigger tire then I definitely vote with tnchevy and say go for the 285/65/18.  The look will be noticeable and you will have the same height as the 265/70/18.  (I heard the argument about wider tires reducing traction in snow when I switched my '00 Silverado's tires from 235 to 245)  Tall, skinny tires have their advantages/appeal but it would require very unique driving conditions to have a 265 mm wide tire out perform a 285 mm wide tire.
Problem is most all 285/65/18's are E-rated tires so much heavier and rougher riding than SL tires. Plus a 285 I think would be close to if not having a rub issue in many cases? I went 265/70/18 with a 1.25 Bilstein level (1.5 spacer before) and I noticed the inch. Wider tires although improve grip in some cases are worse in others mud, snow, ice and have more of an mpg penalty even before the added E-rated tire...
Tyler
Tyler
Unsprung weight is definitely a consideration.  On my last truck I switched from Michelin LTX MS2 P rated tires to Michelin LTX MS2 LT  rated tires.  (Same size-same pattern)   I felt the switch significantly hurt my MPG's. although don't have data to support my "feeling".
    btm
    btm
  • Who's Online   4 Members, 0 Anonymous, 1,373 Guests (See full list)
    • Can ask that about a lot of places.   Holiday sells 91 for $1 over 87 octane. BP 93 is 80 cents. Amoco 93 is 80 cents Kwik Trips is $1.20 for 92 or whatever they have and $1 for the 91.   I know that this is not exactly same as what you are saying with the premium to premium debate of those two stations but why is there such a difference. Top Tier this and that, it's all BS. All the fuel comes from the same damn refinery, so give me a break.
    • Why does Mobil Premium cost 90 cents a gallon more than Shell Premium when their regular offerings are but pennies apart?
    • Was all the way down to $3.69 a gallon but then jumped back to $3.99 just because for some reason.   Diesel floats between $4.80's to $5.10ish a gallon. I even saw Diesel #1 for $6.09 today but nobody in there right mind even buys that in the summer.
    • Mine just keeps lagging or getting stuck on the reverse camera. When I turn off the truck, get out, and close the door it will still stay on. It’s very intermittent and I would not be able to duplicate the issue.
    • I was checking out fuel prices at my farm fuel retailer at their pumps and yes the farm price is a bit lower than the non dyed fuel and was glad to see that the regular farm gas price has dropped a lot from what it had been but what blew me away was the price of diesel as the spread now compared to before the prices went up earlier in the year, diesel was actually slightly lower than gas which was a switch from the theme the last number of years. However that sure isn't the theme lately and definitely not right now. The prices I will post are not from that retailer but just looking at gasbuddy for the main city in this area and instead of posting the lowest price someone found I will list the higher price ( and that may not be the highest price, just whatever someone posted on gasbuddy ).   So regular gas and there are a lot of stations listing the same price for regular is 1.68 a liter, premium 2.00 a liter. Diesel 2.03 a liter for a top price I saw on diesel.   Figures out to 6.36 a us gallon Canadian funds for regular and 7.68 for diesel. With the US exchange rate it would be 4.58 us for regular and 5.53 for diesel.    Thought I would figure that out to get a picture of what it settles out like compared to various US prices and its about the same as the current price in Fairbanks AK as Anchorage tends to be lower. So yes, these would be the prices and higher along the way on the Alaska highway where they know they have a captured market !, for fuel prices for those beginning the long drive back to the lower 48   The problem is our Canadian dollar and going to the states that have the high prices, boy do we pay then !
