Proper usage of Tow Mirrors
Hi I just installed the tow Mirrors and I have debates with my other friend on how to set them and use them. Each had his own way and thought would ask the experts.
they way I set it up is the upper mirrors for the normal everyday riding and the lower one is for the wide angle showing the rear tires for the that tight corners. The issue with this approach is that the objects in upper mirrors are so close and the blind spot is huge.
my friend is keeping the above for towing only and depend on the lower one for the everyday driving
I use mine similarly.  Top glass normal driving/towing mirrors.  Bottoms set to just to the bottom of the rear tires.  I find there to be no blind spots with the way I have them set.  I back into every spot so they help for parking too.
Same here.  Top is for everyday driving and bottom is pointed at the rear tires.
Using the driver side as an example, the top glass is angled outward until the body of the truck just disappears off the right edge of the mirror.  This way I know the edge of the mirror is the truck and I can see the entire next lane in the upper mirror.  The lower portion is angled so that I can see the bottom of the tire in the lower left and some of the lane next to me in the rest. When a car leaves the upper portion of the glass, I can see the bumper and headlights in the bottom until the car is next to me.  There is a moment of overlap when I can see a car in both mirrors.  I set up the passenger mirror similar, but the top glass has to be angled out a bit more since it is just a flat piece of glass, not convex like regular mirrors. Zero blind spots in either mirror, and like mentioned, makes backing into spots with and without a trailer a breeze.
When the tow mirrors are extended out, I just need to angle the upper glass inward slightly and the bottom is automatically focused on the trailer tires instead of the truck tires.  Same principals for view and blind spot.
Mirror adjustment is critical.  Many of us who have driven windowless vans know how fun it can be changing to the right lane in heavy traffic with a mirror out of whack!  I wish to add that I always try to supplement my well adjusted mirrors with good old fashioned shoulder checks.  Most who have driven for a while can remember a "where the hell did he come from??" moment.
Hey guys, I just installed my tow mirrors as well. Seems like the top one is set close to the side as mentioned. But the bottom one seemed like it needed to be up a bit to cover the blind spot. But now I'll have to check and see if my rear tire is visible. Thanks for the expert advice, I do like backing into parking spots rather than putting the bed of the truck into traffic before you can even turn your wheel.
    • I find it amusing the OP doesn’t realize this threads heading includes several engines. He should have posted in the off topic section if he wanted a more narrow focus. I really appreciate and find amusing that he actually pointed out one of my many vehicles. The Odyssey. That happens to use 0-20 oil. I love pushing his buttons.
    • Maybe, but it seems he is the only one that has backed up data to prove what he is stating. I think he is doing this more because he enjoys it and wants to get the information out to us. He's got the knowledge and access to the proper equipment and having the funds doesn't hurt.  I would love to do what he is doing and would do it if and when I hit the Powerball.  I'm not a Tribologist by any means but love to learn what I can.   I would bet there would be doubting people out there if a completely independent lab with high quality work and highly respected in the automotive industry, put out information like this.  The world can't be pleased, one just has to take the information that they are given, do more of their own research to find actual lab data to back up what they are trying to figure/find out.  Most don't bother, they just want to believe what they first see.     I don't have the minimax but my 6.2 in my 2019 Silverado with 64k miles shows excellent UOA results with 0w-20 and for my own purposes 5w-20.  Since not much of a change using 5w. I liked the data sheet information on the SS 5w-20 and figured I would give it a try.  Still the same viscosity at 100℃.   In the end we all just do what makes us happy, life is too short to get upset over trivial social media.   On a side note, I do feel GM has dropped the ball and just cares about the bottom dollar and not quality anymore.  "Like a Rock" has been long gone.  Seems "Built Ford Tough" has as well.
    • Better than stock but that's like putting lipstick on a pig
    • Hello, my 3 month old Sierra Elevation wont recognize a trailer with electric brakes? All the lights work correctly, but no power to the brakes?   This is the factory installed brake controller. If you manually push the knob, the display shows the power % but does not light up like my 2022 silverado.   I have an appointment with the dealer, but was checking to see if anyone else has seen this issue.    Thanks,
    • Been using SS 0w-20 from new, but wanted to change to the 5w-20 because I liked the data on the data sheet, to me it seems like a little better product. But as you can see, not much difference. This is also with running a mix of 10 gallons E85 to a tank topped with 93. It isn't a flex fuel vehicle so any higher I get a CEL for running lean on both banks. Yes my mileage takes a hit. Instead of 20 mpg I normally get on trips I get 17mpg. This is also using EaO17 filter.  What is amazing is I have the AMSOIL cone filter on it since I have the GM Performance intake installed and that air filter has 44k miles on it.  I just take it out and shop vac it off once a year.  I use the upholstery tool on my shop vac.  Works well.
