Hey guys, I'm new to this forum. I have a 2016 Sierra 5.3L 8Speed and it is shifting hard in low gears. Just brought it in to the dealer and they said the trans temp is bad and is affecting the electronic shift adapt. They said a new trans temp is NOT covered under power train warranty.
Welcome to the site!
Where are you mileage wise?
You can open a claim with GM customer service to see if they will offer assistance on the repair cost.
Thanks!
I'll have to look into that!
It just hit 90,000 but I recently bought it from a dealer that certified it so I get 3 months of power train warranty. They said power train only covers internally lubricated parts.
7 minutes ago, 616truckguy said:
Thanks!
You may have to remind them that the transmission is full of internally lubricated parts. Lol
  • 3 months later...
I've got the P0711 code on mine now too.  Search led me to this thread.  My truck is a 16 model with 63k miles on it.  I've recently had the 18 NA 355 trans flush done and now this is popping up on it.  I did find this video on Youtube that goes through it.
  • 4 months later...
Is everyone having the internal connector wiring harness replaced at the same time with the trans temp sensor wiring harness? Dealership wants to do both. Says pip5700c bulletin requires it? I haven't seen the bulletin myself.
17 yukon denali with 60000 and I'm starting to get the history intermittent trans temp code p0711
  • 3 months later...
I know this is an older post, but I had both replaced.
The reason I came back to this is because I got a letter in the mail from GMC about being reimbursed for this repair.  Luckily I kept my dealer receipt on this and I have mailed it in for the reimbursement.  The total price I paid for the labor and parts was just under $400.
I'll update again if/when they send me a check.  It was a pleasant surprise actually.  I guess I'll see if they follow through.
  • 4 weeks later...
2016 GMC Sierra 1500 All Terrain Package.  Had the 8L90 transmission flushed 3 times now because of "Torque Converter Shudder".  The first two times were under warranty, and were before the new fluid was released.  Flushed a third time in March, about 7 months ago, after warranty was up with new fluid.  Shudder issues were resolved but now have the P0711 code coming up.  On the phone the dealer said the temp sensor harness needed replaced and that it would cost around $525.  Called the GM customer service number because I'm sick of dealing with this transmission.  They said there were giving my case to a senior advisor and I would hear back in 1-2 days.  Paid to have the third flush done (around $300) plus my time to keep going to the dealer and taking off work to do so.  Tired of everything to do with this transmission.  Hoping GM will pay for a new harness.  Will update with results.
I have the garbage 8 speed in my 5.3L Silverado and it has been horrible since day 1.  Vibrating and slamming gear shifts both up and down but not all the time and usually only when cold.  (It is especially well behaved if a GM tech is driving to diagnose!) ? Its been flushed and reprogrammed several times with no help.  Last winter on a very cold day (-20F) I was running with the DIC set to trans temp just on a whim and noticed it read just 2 dashes for 5 miles or so then really erratic when it did read. I thought it was weird but hell the trans wasn't acting any worse than usual so what the heck.  So Recently, I see this issue with the temp. sensor on the 8 speeds and it all makes sense now.  I have been watching the trans temp much more closely now and it seems to read pretty stable when temps are summer time warm like 60 and above but the colder it gets the worse it performs and the more temp readings bounce. Now I know why this trans has been so horse sh**t and of course it's not covered for the 5.3L engines.  GM is losing me with this truck I think.
  • 1 year later...
Just had the two codes show up today and just got off the phone with the dealer.  My truck (2016 all terrain 5.3L) is not covered.  Was looking forward to the release of the "refreshed" 2022 tomorrow but thinking I might start looking at Rams.  This truck and transmission is why GMC is the fourth popular truck.  Frustrating to say the least that they can f*ck up a transmission so badly and just walk away from it and leave so many people hanging.  Rant over.....
Is there any programming or calibration that has to happen if I replace the sensor myself?  thanks
  • 3 weeks later...
Have you gotten your answer on this? I just replaced my sensor and no programming was needed.
  • 10 months later...
I have the 2016 5.3L Sierra Denali and this code just popped up I tried to find the part 24297369 but I keep seeing discontinued. Is there an updated harness #?any help greatly appreciated this truck(transmission)has been a nightmare.
2015 Silverado 6.2 8 speed
That part number does not seem correct. I had the same issue and changed the harness myself. I had purchased the harness on eBay using part number 24298757. This part number is the split harness, only the bottom half. You need this sensor, pan gasket24260071  and filter 24274402, all available on eBay or Amazon. You also need up to 8 quarts of MOBIL 124715(blue label) from Rock Auto or other retailers. Rock Auto seems cheaper. Several youtube videos on how to do it.
    • Yes that's right, it's the upgrade that includes the overload spring and all that stuff.   Someday when I'm empty and going by a scale I'm going to stop in and get some weight readings.   Exactly  you should have the ability to change individual settings, in in Canada so I'm driving with kph but then I'm stuck with kpa when I want psi lol
    • You must have that upgraded gvw package which is only available or at least was in 2025 with the diesel engine for the 3/4 ton and that gave the truck physically the larger 12.0 ring gear rear diff and the 3500 rear spring pack. There is a difference in what the diff housing looks like externally as one tell tale and also your truck should have the upper overload spring pack and the frame pads that the pack goes up against.    The pressure the tpms system kicks the alarm in on a stock setting truck, that is a good question and was just from what I recall but I doubt I made any notes on it as I knew for the rear that it was not at all what I was after regardless either. Being that you have a diesel and if running on stock tires the minimum pressure on an empty truck seems to be around 50 psi from hearing of those that have weighted the front axle but the rear axle is very similar in weight to a gas truck and again a near empty truck on the rear could go down to 35 pounds at minimum. However the weigh scale is the proper way to know for sure as a guide.    As to changing the readings on the dash from metric to the US measuring system, oh yes that is done easily but what I was attempting to explain was that I can't pick and choose items I want to have in US and those I still want in the metric system at the same time as its either all or none. For example lets say you drove into Canada and switched your dash over to metric so your speedometer read in km an hour, well then your reading kilopascals on your tpms readout and your wife looks over and says what the hell is that saying in the tpms screen and you say "darned if I know, I think its Chinese" !
    • This is partly why I decided to have switched over to Amsoil SS as a way of hopefully preventing the buildup of the sludge/carbon on the pistons and clogging of the oil control rings and the carbon that would cause the compression rings to stick in their grooves as well as stay cleaner up top of the heads in the valve train in the first place, an oil that has tested better by third party testing over typical shelf oil and also doing my best to run relatively short OCI. However in saying that I don't think there is any way to easily prove the oil I was using prior allowed for a buildup at the OCI I was doing, nor in the other direction to make claims the Amsoil is keeping everything clean either. There really isn't a window into the engine is there to know anything for certain even if oil samples were taken for example that showed still healthy oil being dropped out of the oil pan other than engine tear downs that extensive and expensive testing of oils does to actually visually see what is really going on inside the engine. I wish there was some easy method of seeing what is going on but I don't happen to be aware of that if there is.
    • My truck is a ¾ ton but my placard also says 80 for the rear tires, I think I might have the upgraded suspension to the 3500 series maybe.   I put my air down to 60 and the light was still on, and there was no way I was putting over 60 psi in the rear empty and not towing because I knew the actual number Toyo gave me and I didn't wanna ruin the center of my tires!   And you actually can change it in the settings from metric or is and it will show kph or mph then when you go into your tire settings it will be either psi or kpa, but it would be nice to just change it directly on the tire psi page
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
