You have the bora 1.75 right? How much do they run?
Yup, like $125 a set. As long as you get a quality spacer you’ll be fine
Close to pulling the trigger on a set, the wheel tuck really bugs me.  I was unaware of the difference in track width but now that I know I can't un-see it.
Gonna order 1.5" for the front and 1.25" for the back.   I shouldn't have any rub in the front with the stock suspension and 20" wheels when using the 1.5" spacer right?
78.1mm / 3.08" the proper centerbore for hubcentric?
Do you have a lift or level?
no completely stock from factory with no plans to do either.
Someone correct me if I’m wrong but I thought the front stuck out .25” more then the rear on stock suspension?
That’s correct
Anyone know how much of the tip of the studs is not threaded? Also how much I can cut off and it not affect the threads/performance of the stud? Thanks in advance
ya i wrote the wrong thing.  I want a square setup.
I wasn’t questioning you I just didn’t want to screw it up myself because I’m thinking of doing something similar , only difference is I’m already flush with my fender with my offset in my wheel, I’m just trying to achieve a little more stance
I just ran out and removed 2 lugs of mine(one locking one oem).  There is 14mm between the top of the stud and the start of the first thread.
Funnily enough it took 14 turns to get the lug nut tight.  Therfore 14 threads of engagement is what is used stock.  I probably wouldn't go less than 10. (this is assuming stock wheels your aftermarket may be different thickness which will change the number)
What is the torque spec for the lugnuts?
I believe it’s 150 ft lbs. but you got me thinking, even tho it takes 14 turns doesn’t mean that you need all 14 to “hold” the wheel on, so let’s say mine met the wheel at 10 turns to tighten, does that mean that the threads before that are not really needed to secure the wheel properly? Or what am I thinking is wrong?
1 minute ago, FORGIVEN06 said:
I believe it’s 150 ft lbs. but you got me thinking, even tho it takes 14 turns doesn’t mean that you need all 14 to “hold” the wheel on, so let’s say mine met the wheel at 10 turns to tighten, does that mean that the treads before that are not really needed to secure the wheel properly? Or am I thinking is wrong?
how many threads of engagement is what is important and is what provides the strength needed.  I'm not quite sure what your asking.  There are unused thread at both the back of the stud(the wheel thickness) and the back of the lugnut(the part where the unthreaded stud resides once tightened).  That 14mm of unthreaded stud is useless and you can cut it off with no ill effects.  adding spacers essentially increases the thickness of the wheel and therefore more threads are covered and cant be used.
So take for example the lugs that come with bora wheel spacers are only approximately 1/2” long. So in theory if I have at least let’s say 3/4 of thread to use then the lug should be able to tighten to specs no problem. So if there is any more then “needed” then I could cut this off and it could still work? Or is there a reason that this could be in safe?
You can cut off any threads that come out the backside of the tightened open faced nut without affecting the strength.
The only real safety issues regarding spacers is
1. slip on spacers (the ones that dont have its own studs) these spacers essentially increase the thickness of the wheels and less threads get engaged.
2.  using adapter style spacers that are too thin.  When this style of spacer is too thin the factory lug nuts stick out past the face of the spacer and prevents the wheel from sitting flush against the face of the spacer.  This is the scenario when you would have to cut the stud so its behind the face of the adapter or the wheels need pockets on the backside between the mounting holes to accommodate the protruding studs.
3. Spacer out of balance.  The spacer is part of the rotating assembly along with the rims+tires.  If the spacers arent balanced you will have the same symptoms as your tires  being out of balance.  The only solution to this is to buy quality spacers.
4. Wrong hubcentric size.  If the adapter hub size is larger than the wheel it will prevent the wheel from sitting flush this is a very unsafe scenario.  If the adapter hub size is smaller you can get a hub ring to make up for the size difference.
    • I have a hard time seeing oil from 'below' the rings 'pooling' in the cylinder. For an amount great enough to pool getting past the rings I would expect to see that same amount contributing to other noticeable symptoms, low compression, blow by, etc. You could try investigating for a stuck, gummed or carboned up ring, maybe an oil with different detergent strategy. Some other shade tree solutions like adding a detergent (or mystery oil) to the chamber and letting it sit, I've also heard of a heavy use of 'engine braking' to load the rings differently.   I would first be looking at oil entering from 'above' via a head issue, or intake/PCV issue. I suspect that the oil is entering cylinder 8 combustion chamber at all times but is getting burned off during each combustion event preventing a 'pool' from forming and lessening visible oil burning smoke. This leads back to valve stems or PCV system as the only route for oil to enter the chamber from. I would expect a PCV issue to not be isolated to cylinder 8 though.   Other considerations, how long does it take the pool to form? Could you look for the oil trail via the borescope? (Run the truck, shut the engine off, as quickly as practical, pull the plug and insert the scope and record to see how long and hopefully where from.)
    • National Average back up to $4.04 for gasoline and $5.35 for diesel.   https://gasprices.aaa.com
    • I’m out of ideas on this truck. 2020 Silverado 1500. 5.3 135,000 miles. Has a p0308 and p050d codes. Smokes From exhaust when cold. Compression test passed. New plugs, wires and coil on cyl 8. Same issue. New coil on 8, no change. Replaced injectors, no change. Bore scope showed oil pooled on the piston after sitting overnight. Pulled head and had machine shop check it out. No cracks. Stem seals looked good, replaced anyways. He also ground valve seats. Put it all back together and still have the same issue. Bore scope shows oil on the piston again. Leaning towards maybe a cracked ring but unsure. Cylinder looked good when the head was off, no scoring or scratches. Any ideas on what else I should look for?  Appreciate the help
    • Just want to make sure it is covered by Special Coverage N232395310 Evaporative Emission Purge Pump 2021 Silverado 1500 Custom 2.7L L3B ~100k miles I'm getting DTCs P146B and P146F. VIN 3GCPWBEK2MGxxxxxx   I spoke to a person that works at GM and he said it is not covered after checking my VIN.   Is there anyone here who currently works for a GM/Chevrolet dealership and has access to GM Global Warranty Management / Investigate Vehicle History who could explain how the VIN eligibility is determined?   thank you
    • Thanks for all that information, I might purchase one and see if it will work for me, if not they may let me return it! Yes for sure the tires are definitely within limit for my truck empty, and when I do tow I'll definitely make sure to raise the rear psi for the amount of weight that's going to be on it.
