Tire load range rating
I have a brand new 2018 Silverado 2500 HD that has the factory Goodyear SR-A all season tires (load range E).
I have the opportunity to buy a set of brand new BF Goodrich All Terrain KO2’s at a real good price.  However they are a load range C tire.
I don’t tow or carry any heavy loads so would these load range C tires be OK to use on my truck ?
Load range C tires (KO2’s) are rated for 2755lbs.
Load tange E tires (KO2’s) are rated for 3195 lbs.
  • 1 month later...
Yeah, load range C would be better if you are not towing or hauling heavy.
2500,  crew, standard box,  4wd, SLT, dmax:
From GM's weight calculator:
Weight Calculator (lb.)......Front .......Rear ........Total
Base................................. 3,853.9......2,678.1....6,532.0
Options................................756.2.........112.9.......869.1
Total .................................4,610.1.......2,791.0....7,401.1
GVWR................................5,200.0.......6,200.0...10,000.0
Total Payload.......................589.9.......3,409.0......2,598.9
