Waterfowler41 Posted October 25, 2018 Posted October 25, 2018 Any chance finding a bull bar or bush guard that lets you still have tow hooks?Doubtful, not to many areas to mount these too on the front of these trucksWaterfowler 41’s Youtube channel: https://www.youtube.com/user/brittmork
Waterfowler41 Posted October 25, 2018 Posted October 25, 2018 I wen't with the RC led bull bar as well. Install is dead simple with the exception of one bolt on the Factory tow hook. I like the look of that Deezee push bar above. I cut a bolt on each size and I will agree, that’s the work park of the install. Everything else is easy peasyWaterfowler 41’s Youtube channel: https://www.youtube.com/user/brittmork
roadblock Posted October 25, 2018 Posted October 25, 2018 18 hours ago, Crazyjoker77 said: I wen't with the RC led bull bar as well. Install is dead simple with the exception of one bolt on the Factory tow hook. I like the look of that Deezee push bar above. Did you hook up the light bar yourself too? Is that part hard at all?
Crazyjoker77 Posted October 26, 2018 Posted October 26, 2018 2 hours ago, roadblock said: I install everything myself but I did not use the wiring harness that came with the kit as I previously installed the factory upfitter switches to control all my lights. I would imagine its fairly simply and like installed any other electrical accessory. Worst part is probably getting the wire/switch into the cab. If you wanted to wire them into the high beams it would be dead simple. I'm not overly impressed with the included lightbar though. I did benchtest it when I first got it and it does indeed pull 90W as advertised but its all flood and doesn't throw very far but it does fill out the dark area caused by the cab from my roof mounted lights. (2X 12" 72W Combo beam)
