My 2018 Gmc Sierra (55k miles) had the U1510 code this past week. I noticed the check engine light came on after heavy rain day down here in houston. Anyway...the code has to do with the Active Grille Shutter having an electrical short.
Dealer quote @ $750 to replace whole unit. (Parts and labor)..i was fortunate my ext warranty covered it.
I researched the part online..you can buy the part@ $220 and pay your local mechanic shop to replace unit and save $$.
Did you remote start quit working as well?
On 10/24/2018 at 11:52 AM, Joel Kingston said:
Got a baffling issue going on.   Couple of days ago the check engine light came on with a 2017 1/2 ton Gas Silverado.    Had a dealer trouble shoot it to run the codes.   It is a communications fault and comes up U1510.    They want the truck for a couple of weeks so they can trial and error a connection or wire issue.   I am reading on-line a LIN communications break down is somewhat common,  maybe with the ECM,  the BCM or other module such as the HVAC.   Anyone seen a common issue with these newer 1/2 tons that can prevent a trial and error approach by the dealership.   I don't really want the truck dismantled while they trial and error the connections.
Thanks!
Any chance your remote start also quit working? I’m having the same code right now with my 2017 Silverado and the only things I notice different is the remote start doesn’t work anymore and my oil pressure drops down to 20 after idling for more than 20 minutes when not driving.
Thanks!
Thanks!
Thanks!
Thanks!
Check engine light disables remote start.  Oil pressure sounds normal
I have a 2017 GMC Sierra and got a code of U1501 LIN Bus 1. Any ideas?? I've had no issues with performance and local parts store cleared the code saying they have never seen it before.  Will watch to see if it comes back but wanted to see if there were any thoughts on corrective action or maintenance to keep it from happening.
  • 4 months later...
Hello I’m having the exact same issue with my truck it’s a 2017 GMC 1500 sierra 5.3 L 4 x 4 codes that are coming up are U1510 and U1501 can’t figure out the problem what solved it for you?
On 8/9/2021 at 11:26 AM, yellowwrecker said:
How are you getting the K?? Part of the trouble code ?? Though a GM Tech only scan tool or can a cheapy do it ??
I have a 2018 Z71 Silverado showing U1510
You all have a 95% chance of needing the active aero shutter that's behind the grille.  The shutter actuator fails internally due to moisture, corrosion, etc. and pulls the LIN BUS communications line which then sets the U1510.  U1510 and a malfunction of the shutter set the check engine light because the shutter is tied in with the ECM.
Replacement of the active aero shutter will resolve this issue.
Edited by newdude
I have a 2018 silverado it recently started with a check engine light the code that shows up is u1510 k9 whenever i go to remote start it, it shuts off. I manually start it the code won’t show up it runs fine no issues
  • 5 months later...
Any of you guys ever get the U1510 code sorted out? I'm having this issue with mine now. I changed the grille shutter last weekend and the light is still on
Well the dealership figured it out, bad connection at the ECM. All the hours of research I did and never saw this fix.
Hope this helps someone in the future figure out there issue.
    RyGuy43
    RyGuy43
  • Who's Online   5 Members, 0 Anonymous, 534 Guests (See full list)
    • can you tell if the reader is actually trying to get codes, and the pcm is reporting none, or is your reader just silently failing because it's not communicating with the pcm?
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
    • First off you mentioned "Toyo Says" and then gave the pressures 45/50, was this some person at the tire shop that pulled those numbers out of his head ?   Now of course I can't know your exact axle weights front and rear, however I have much the same pickup as yourself other than not knowing your starting weight as per the pounds the truck rolled out of the factory at due to the options yours did or didn't come with or what you have added beyond the extra tire weight. The correct way to know 100% where a person is at is by weighing each axle with the typical weight the vehicle is driven with and that means taking into account passengers and making sure you figure in a full tank of fuel and a little grace for whatever you may put in the bed "groceries" !    I am looking at and not that it really matters as all the tire companies use the same charts anyway, but I am looking at the comprehensive Toyo tire chart in the section that your tire falls under and I know it sounds confusing but your tire is not an LT metric tire like your factory tire but instead because its a standard inch measured tire its under a different category called an LT floatation series tire. That makes a difference as LT metric tires they don't want to see run below 35 psi at highway speed where as with the LT floatation series it can be run down to 25 psi on the highway as long as the weight on the said size of tire is agreeable with or less than that minimum 25 psi. It blows many people away that how is this physically possible, an empty truck for one thing and larger tires with the same size wheel diameter have a lot more air volume so they can carry the same weight as the smaller tire with less air pressure.    So my truck, I have the stock 275/65R20 wheels and tires and I have a bit of weight in the box with a bak flip cover and a rubber bed mat and some tools and spare gas. The front of my gas truck weighs a bit more than some trucks of the similar spec due to double batteries and alternators. However with full fuel and just me in the truck I am weighted such that I can run 40 front and 35 rear and so that is what I have done since day one.    If I base your truck at or slightly below the weight of my truck, in theory with your tires going by the tire chart you might be right around a minimum of 30 pounds front and 25 pounds rear. Of course that would hit pretty much minimum cold inflation pressure one could run with that tire size and a near empty truck. If you have access to an accurate weigh scale to do individual front and rear axle weights I would suggest you do that and make sure your topped up with fuel and whatever else in the truck before you weigh it and then you will have a great starting point to work off of and figure out what your bare minimum pressures are you can safely run. If you do much in the way of hot weather high speed driving, bumping up a bit for a safety margin is never a bad idea but just depends on what type of driving you do. I will include the Toyo chart and the floatation series sizes start on page 31. Without a doubt at these pressures I am speculating at minimum wise for your truck, it would most certainly ride very different then it did when you were using 55 lb front and rear.     https://www.toyotires.com/media/pxcjubjs/application_of_load_inflation_tables_20200723.pdf
    • Take an automotive stethoscope to the vacuum pump. Iirc those tick as well.
    • This landing is worse than most. Patchy blacktop with washouts, soft gravel/sand at bottom that washes out with every heavy rain. I tell everyone to put it in 4WD. A lot of them think they can pull out their trailer in 2WD. They end up digging a hole and then putting it in 4WD.  The lake is a pristine lake and has a lot of money on it. There are several wake boats and lot of large tritoons. The people with the money don't want it improved because they don't want more traffic.    Boat Landing 1.jfif Boat Landing 2.jfif Boat Landing 3.jfif
