6.0 vs 8.1
The 8.1's are few and far between around here.....
So I'm contemplating a 6L Vortec instead...as long as it has the 6-speed tranny.
Now obviously, the 6 won't have as much torque and HP as the 8.1 but any 6L owners out there; how does it tow?
Our trailer is only 5000 lbs but there are a LOT of hills between here and where we go...I was able to tow with my old F350/460 ci and 5-speed manual, but it was a chore.
I have a 2011 2500hd. 6.0 6L90 4x4. My truck is lifted 8 inches on 37s and I tow a 34ft travel trailer plus equipment and gear, I’m looking at around the 10k mark. Pulls good, not great because I still have 3.73 in it. Average 8mpg with wind behind me. But with 5k you’ll tow great. My truck basically will tow anything I hook up too. When I swap gears to 4.88 I’ll be golden.
Good to hear these voices!
When all is said and done...I'll still be shopping for an 8.1. But it's good to know that the 6 will handle the load, if I can't find one.
Went to look at an '05 8.1 the other day....what a rust-bucket! And the owner insisted it "needs nothing".
Sure, other than new brake lines...every bolt in the frame...suspension brackets...fuel tank...........................
Ow, lol. My truck with 4.10 growls with 10k behind it.
OP, if you're after an 8.1, you'll only find it in the older 99-06 body style(s). And if you settle for a 6.0, but need the 6 speed, you'll have to look for '07 and newer.
Yeah...I'm OK with that.
There's an 05 in the area with the 8.1 and 5-speed Allison...hasn't moved in months, hopefully I can probably wait a bit longer. Our gas prices are a bit insane right now so nobody really wants a 10MPG monster (or so you'd think).
Quite a few 6L's to be had...I don't really need another truck until February or March. Have to sell this Duramax, first.
Yeah at 70 it searches between 4th and 5th. About 2500rpm in 4th around 1800 in 5th. It will never go into 6th when towing because of the gears. When I go to 4.88 it will be basically be like 4.30 with the tires. So little higher than factory means. But will be good. The 6.0 is stout. It will do anything you want. There’s a massive aftermarket support for the 6.0 Ls and the 6L90 becyaee they are a common swap in basically everything.
Nice....
So what is the life-span of a 6L...are there many beyond the 200,000 mile range?
I realize that a lot of it has to do with maintenance and so forth, but some engines just seem to last forever.......
Nice....
Mine is at 102k. I got it with 82k. I barely drive it anymore, just on trips basically. With maintenance and taking care of it, there’s plenty over 200k closer to 300k. I personally had a 2005 1500 with 5.3 that had 280k on it before getting rid of it. And didn’t get rid of it because of mechanical issues. Truck was great, ran awesome. It leaked oil, but it was old and high miles, it’s expected. I could jump in that truck and drive it anywhere no issue. The 5.3 and 6.0 are basically same motor in nature. Both LS based. The 6.0 replaced the 8.1 if that tells you anything from Chevy end. There’s a lot of commercial companies that used the 2500 Chevy with 6.0 that tow heavy loads basically to stay away from diesel prices. I have never had a mechanical issue with my truck. I have an exhaust leak that’s starting at the manifold. But that’s it. Gas mileage isn’t great, no gas truck pulling a load is. But it will work and keep taking it no issues. Plus I believe parts may be a little easier to get for 6.0 vs a 8.1 being that they are a little more common.
A bit of research, and I've answered my own question!
https://media.gm.com/media/us/en/gm/autoshows/chicago.detail.html/content/Pages/news/us/en/2010/Feb/10chicago/0210_vortec.html
"The Vortec 6.0L features a cast-iron cylinder block, aluminum heads and variable valve timing. It was developed for heavy-duty applications and has undergone the most rigorous lab- and road-testing process in small-block history. It is validated to achieve 200,000 miles of operation in typical applications."
The 6.0 is definitely a tried and true long lasting work horse engine.
OK... I'm definitely a newbie when it comes to GM trucks because I've been driving Toyotas and Fords since the 70's but now I have picked up a 2009 Z71 4wd 2500 mostly because of the cabover slide in Lance camper that it came with.
I am falling in love with the truck but I have almost no idea what I've bought.
How can I tell whether I have a 6.0 or 8.1 motor?
How about what transmission I have?
Rear end axle ratio?
Sorry for all the newbie questions but I looked around and didn't find an FAQ that would help me.
*** EDIT ***  OK... I found a link that told me to check the 8th digit of the VIN code and it's a K which I guess means it a 5.7L small block 350ci engine. Can someone please tell me where to find more information on this motor? Everything I've found so far doesn't even mention it being produced as late as 2009 so the confusion mounts. I'd like to know HP and Torque and other specs as well as information on how reliable it is etc.
*** EDIT #2 ***  The confusion continues... I got on NADA Guides dot com and they say the motor that comes with my pickup is the 6.0L and it has a 6 speed transmission. So now I am once again confused. Is it a 5.7 Liter or a 6.0 Liter? The plot thickens.
TIA
You can either take the vin to a dealer, and ask for a build sheet (they may or may not give you one, and may or may not charge you for it), or you can decode the RPO codes on the sticker in your glovebox.  Those 3-digit codes detail what options GM installed in your truck.  It's useful to keep this list handy when buying parts for the truck as well, as some parts vary depending on what options your truck has (brakes, transmission oil lines, alternator are just a few things that vary depending on what options you have).
    MASONV88888888
    MASONV88888888
  • Who's Online   5 Members, 1 Anonymous, 922 Guests (See full list)
    • I usually do as well or better than the sticker for mileage. Usually better going west than east. North then South. Wind makes a difference. I’m not usually a conspiracy theorist. But it did dawn on me I’m going by the vehicle calculation. Now that would be interesting.
    • https://www.msn.com/en-us/autos/news/fuel-economy-stickers-don-t-tell-the-whole-story-aaa-data-reveals-why/ar-AA26ocHk?ocid=winp2fptaskbarhover&cvid=6a4122ea3dae47e5b8dfbed5d4fd3d55&cvpid=648f6b4fc2fa4eddb4c12893aeb957ed&ei=59
    • What’s missing in all this is patience and investment in the future. Buy a 170K starter home. Ten years later sell it invest in a more expensive home. Eventually you’ll have a 600K home and pay starter home payments. Buy a starter car. Maintain it well. Save the payments after it’s payed for then buy an expensive car if you desire. Buy a tumbler make your own coffee, pack your lunch. Cook your own dinner. Most importantly take care of your car.
    • People mislead themselves. Statistics are highly useful indicators.   Here's the tie-in to this thread. If an oil sample tests shows a wear indicator of 7 using cheaper ACDelco oil, and a wear indicator of 2 (lower = less wear) using a particular brand of Mobil oil, and wear has a linear relationship with engine lifespan, anyone could assume that Mobil is reducing wear by more than 50% (let's just say a 200% reduction for you red state people trying hard to do math) which leads to increasing engine life by 2x. Perhaps, in a vacuum, by itself, when dreamed by AI.   Yeah?! That's what the statistic is saying, isn't it?   No, it isn't. It didn't come out and say engine life is doubled. That's a very bad assumption, and a case of severe myopia by assuming something potentially untrue about the only data point in focus.   Average cost of a new car is 50k. You bet it is.   The median cost of a new car is more like 35k. Expensive cars are skewing the perception that "average" now means a $50k price of entry for a very average automobile. And that's not true. People who don't understand statistics twist the living heck out of them to mean all sorts of things they don't actually mean.   "Average" new car payment is $1000/month. Yep, it is. And in that number are all the $35k new car buyers who bring significant equity, and the $25k new car buyers who finance the car for a month just to get a rebate, and then pay it off. Know what isn't in that number? All the payments made by people who don't finance a car.   Picking one's own data point (don't have a car payment, never paid $50k for a new vehicle, my house cost $170k, I afforded a middle class lifestyle on $4.50/hr) is just a data point. Just like earning $25/hr in an area where the median home price is almost $1 Million is a data point. In fact, it's a lot of data points given that 80% of the US population lives in/around major cities. They're not idiots; the vast majority of them do it to make a living because that's where the big money is.   The highs have become higher, lows have become lower, and how your personal mileage varies is not truth for an entire country. At the same time you can't NOT acknowledge the data. While it doesn't paint YOUR personal picture, it certainly tints the reality that you also live in, as does your single data point.
    • Glad you had success with it. I did as well, but about 5-6 months later it returned. Tried again, same result. This was after the dealer made several attempts and never even got it to slow down.
