2019 Denali...I'm quite disappointed
14 hours ago, j-ten-ner said:
I think this is the actual problem.
so long
j-ten-ner
I remember reading back in 2011 a top Ford executive stated they were amazed at the prices people would pay for trucks. Back then it stated average profit for mfg. was 10,000. Read a month ago average profit for mfg. now very close to 20,000. Obviously these profits are based on upper level trucks which most are buying. They are riding a Red Hot Fever of buying and are going to keep it going as long as they can. Maybe they are even forgetting everything in the auto industry is cyclical.
  • Replies 48
On ‎11‎/‎21‎/‎2018 at 7:55 PM, j-ten-ner said:
I'm confused.
so long
j-ten-ner
Can I just be stunned :lol:
$20,000 PROFIT and squeal like a pig if you ask for a set of floor mats. :rolleyes:
I wish I would have read or joined this site before I bought my 15. I sold my 2006 Silverado z71 with 108,000 on it and it ran perfectly fine. A little over 9 years a set of tires 1 hub bearing and a set of break pads. That's it. After having my 15 now for a little over 3 years now I do like it but I do miss a lot of things on my o6. I know the guy who bought it and see him every once in a while and all he has done to it was a break line. I do believe that 2006 was the last true good year for these trucks.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   4 Members, 0 Anonymous, 1,295 Guests (See full list)
    • This is interesting. My quote tagged here is different from my original quote. After I’m driving them longer. That isn’t me. I don’t talk that way. I definitely wouldn’t express myself that way. Interesting.
    • I have the same running boards on my truck and I do agree they are bulky. I also find myself stepping over them when getting in and out of the truck. Besides providing protection to the rocker panels, they aren't very useful.  I will be replacing them soon with the Amp Powersteps.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
