Brown connector on BCM - Jumper  pin 10 Brn/wht to pin 22 Blue.
Fogs will come on with park/head lamps now. No need for diode.
Assume this for 2019  do you still need the diode for a 2017
No diode needed for the 2019.
Using a diode on the older trucks (2018 and down) was an option. I never used them.
Still illegal in most if not all states/territories to have fog lights and bright headlights on at the same time.  Around here, that's an easy (and expensive) ticket.  But as they say, your mileage may vary . . .
If your brights are on and you pass a LEO you deserve a ticket.
I've helped numerous LEO's with this mod dating back to 2010.
As a matter of fact all ALEA Tahoes have this mod.
Edited by jericbarg
This mod keeps the fogs on anytime the park lamps and/or headlamps(hi and lo beam) are on.
If you just want to keep them on with hi beams connect a diode  from pin 18 (bn/vt) to 10 (bn/white).
Setup this way you will have to initially  turn the fogs on manually to activate with lo beams.
Edited by jericbarg
has anyone done this yet on their 2019?  I swear that brown connector (and the wires) is much smaller when compared to the old K2 trucks.  Seems like a real job to get a diode inserted..
Just placed order for my diodes on ebay [emoji4]
Had this mod on my 17 and loved it.
Which ones should we bridge to make the cargo lights come on with reverse lights? I had that one and it was nice to unlock from far away and see all lights come on and shine through the parking lot!
 @Jerry’s Denali
Any way we can get the mirror work lights to stay on while the truck is in drive? I didn't realize the truck had to be in park for them to work but they it makes sense from a DOT stand point.
Sent from my ONEPLUS A6013 using Tapatalk
    MASONV88888888
    MASONV88888888
  • Who's Online   1 Member, 0 Anonymous, 1,506 Guests (See full list)
    • I have 2 choices.
