Collision detection .
18 hours ago, khaledsamy36 said:
Does any one know how to turn off the collision detection system on 2017 Sierra ( if at all possible )
The Collision Alert control is on the
steering wheel. Press [ to set the FCA timing to Far, Medium, Near,
or Off. The first button press shows
the current setting on the DIC. Additional button presses will change this setting. The chosen setting will remain until it is changed
and will affect the timing of both the Collision Alert and the Tailgating Alert features. The timing of both
alerts will vary based on vehicle speed. The faster the vehicle speed, the farther away the alert will occur. Left hand side of steering wheel, inside row, top button.
The button on the wheel only changes the near ,far , medium , it does not have off mode
It should, this is straight from the owners manual, FCA can be disabled with either the FCA steering wheel control or,
if equipped, through vehicle personalization. See “Collision/ Detection Systems” under Vehicle
Personalization 0 160.
Might try setting on screen Vehicle  then climate / air control , then scroll down I thought I saw on off for that when I was looking for auto rear defog.
You are correct Sir! Home page, settings, vehicle, collision/detection systems, then it will give you options including, off.
Thank you , you are correct as well , only from the infotainment system I was able to stop it .
The funny thing I always wanted the alert without the automatic brake and it was there as an option .
Thanks sir .
Thanks sir .
You are very welcome. Merry Christmas!!!!
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
