20 minutes ago, DenaliDH said:
What is the diode for in the gray connector on the left?
Edited by SS502
Left diode is for puddle lamp (on DL3 Mirrors) to follow interior dome lamps. This is a requirement for 2014 trucks that upgrade from DL8 Mirrors to DL3 Mirrors.
I wanted to share what I found...this mod is awesome but my first choice of diodes was not. I ordered the right diodes but the first ones I ordered has a wire so thin it just slid right on through and didn’t seem to make contact...the second batch has a much thicker wire and worked perfectly. I’m not saying the thin won’t work but I don’t think they would have stayed in place even if I could get a good contact.
On 12/28/2018 at 10:17 PM, pgamboa said:
Need a diode to have your cargo lights follow the reverse lights.
Same diode for fog lights that’s with high beams on?  Better photo of exactly where it needs to go?
TIA
TIA
Yes. If you zoom into the pic, it’s the top slot, and two slots down from that one.
That’s exactly the problem I had, my first order of diodes simply were so thin it would not make a good connection.  So the Chanzon were the ones that worked correct?  I will give these a look.  Thanks !
Edited by 4weight
Yes Sir, nice and sturdy...Chanzon ?
PM me your address and I’ll send you a few of them. I needed 3 (not 3 for the mod, I ruined 2 of them) just because I kept bending them too much, finally did use needle nose and that worked much better but I’ll send you like 10 of them on Monday.
Edited by SS502
I must be blind, I cannot find where this is located.
No worries. I get asked this question all the time.
I had to sacrifice a diode for its wires and solder them to the one I was using for the jump and it worked a lot better for me. Bifocals suck sometimes!IMG_3392.jpg
On 1/17/2019 at 8:06 PM, CovetedStyle said:
Under the dash driver side
That explains why I didn't see it in the engine bay. Thanks
43 minutes ago, Spedelbrock said:
This is probably a stupid question but when installing the diode do you disconnect the battery?
I didn't, didn't even have the truck running.  Just crawled under the dash, and started pushing the diodes into place.
Dear members,
I followed this thread but i running for some issue.
I realize when i am unlocking the doors the revers light does not come on. is this normal or my car has middle east spec non USA?
Edited by Abdulrahman Alessa
