Cracked 8 inch radio screen
Welder2014
last fall I cracked the touch screen on my 2014 Sierra with a suction cup mount. Has anyone had to replace theirs? Any ideas other than replacing the entire radio. Thanks
Good time to upgrade to the '16+ setup, then you won't need a cell mount anymore since you can just plug your phone in for Android Auto, or if an Apple Fanboi, CarPlay.
I don't own a cell phone. Damaged screen using my Garmin while driving the Taylor hwy to Dawson in the Yukon. Cell phones don't work in this location. Thanks.
Check this out that I came across the other day.  12.1 Inch Android 7.1 Stereo with GPS
the screens are super easy to replace, its 4 screws if i remember correctly. I just checking on car-part.com and there are several junkyards in Anchorage that have them for under $150
Do the screens need to be programmed before installing?
Thanks for the info that what I was wanting to just replace the screen. Wanted to keep the stock setup probably will be getting a 2020 in a year or so.
    Fishboat
    Fishboat
  • Who's Online   3 Members, 0 Anonymous, 481 Guests (See full list)
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
