47K
2015 Silverado LT Midnight Edition
4.5” CST suspension lift
You’re safe [emoji1303]
Sent from above
Sent from above
I’m going to take it in again soon I’m due for an oil change. Hope they try to help
Do your homework prior to getting to the dealership, know your warranty inside and out. Also, you’re not stuck using only that one dealership, you can take it to any GMC or CHEVY dealership. They do not communicate with one another unless same company
Sent from above
chrispassas - tell them you will take it back to them every single time it shudders - and, then do it ... force them to go for a drive WITH you and record the RPM gauge ... they are slowing rolling you.  The fluid change in mine appears to have completely fixed the problem.
TXgreek - could possibly be oil on MAF - they are incredibly sensitive ... not trying to start another war, but my understanding is that air filter mods result in performance improvement in a VERY small range - like at the max HP.  Never made sense to spend the bucks to do it to me.
I have been a little too nice, do you have the 6 speed?
Gah -  sorry - Chris and TX!  Mixed up names and topics ...
Chris, comment re shudder was meant for Eric with the 2018 6.2 and 8 speed.
TX - comment re MAF was meant for Chris ... been thinking more about the MAF and oil contamination ... could be the problem, but not clear.  6 speeds were not known for the shudder issue prevalent in the 8 speeds, were they?
IMHO, it’s more of a mental high than anything else. I’ve run cold can induction in prior vehicles and in all cases actually getting negative returns. It’s a mental high, that’s all. These engineers would’ve made a larger intake to make draw in more air to make more HP if they thought it would’ve helped improve against the competition. I’d rather change the stock air filter more often than install one of those. Last vehicle I had it on was my 14 with a 5.3, negative performance. This type of added kit only works positive performance if your motor is completely tuned (not canned tune) in addition to headers, exhaust, motor enhancements and much much, more. Back, starting in my teens, my stock Buick T Type and later in my 20’s a slant nose 930 destroyed every street legal hot rod that went up against me. Our trucks are designed for towing, hauling and going through drive thru’s lol. Just my opinion.
Sent from above
Both, issues are with both 6 speed and 8 speed
Sent from above
TX,
Copy - however, from my limited reading the issues sound a bit different ... 6 speeds appear to clunk badly and not shift smoothly, whereas the 8 speeds are much more likely to shudder and rattle AND clunk badly on down and upshifts at certain points ...
Perhaps the new fluid will help the 6 speeds as well?
I am still amazed this sort of thing can even happen - given the development costs and opportunities to beat the shxx out of them during testing ...
"Life is a beta test ..."
Did you end up getting the fluid change for your 6speed? I have an 18 6 speed and it shudders and clunks like crazy.
No. But I did just get a black bear performance tune and the transmission is basically how it should be from factory now.
Could you expand , whatvwas it doing before and what have you noticed since the tune
Before it would always clunk after letting off gas then coasting. It wouldn’t know what to do if I wanted to go fast. Justin turned off AFM under 45mph and cleaned up the shift points. It really does drive like a different truck. Still think I need to regear because of my tires but other than that I’m very satisfied
It's been 3 weeks now since I had the trans flushed a d new fluid added in my 2016 Sierra 5.3 with the 8 speed trans. The shudder is still gone! Love it!
I was out of warranty and had to pay out if pocket, the dealership which sold me the truck refused to do the flush for free. ( That's a long story, they pretty much hid the shudder from me). They wanted $700 to do the flush, I laughed. Went to the other local GM dealership in town and they charged me $350. I'll never go back to the other and am letting everyone else know as well how crooked they are.
Sent from my LG-LS993 using Tapatalk
    TopBo
    TopBo
  • Who's Online   0 Members, 0 Anonymous, 795 Guests (See full list)
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
    • Is it an optical illusion in the pic or is the truck really squatting that much horribly?
    • My initial introduction was here.  It's hard to believe that I last posted in February 2013, having just deployed to Kyrgyzstan.  Since then, I've retired from the military and the 2006 Sierra SLT Z71 that first brought me to these pages was lost.  I went forward to Afghanistan in March 2013 and did a lot of sitting behind a computer on brigade staff.  Within 18 months of getting back to the States, I was selected for Drill Sergeant duty, after which I moved back to Virginia (my home state and where I served from 2004-2008).  That '06 Sierra did a lot of driving between Louisiana, Georgia, and Virginia, and ended up with nearly 320k miles by 2022.  By then, the registration had been expired for a couple of years, but the pandemic had all but eliminated tickets for such transgressions.  Admittedly too, I usually drove my wife's SUV or son's car the 2-3 times a week I had to report to work.  Teleworking sure was fun while it lasted.   I started my retirement leave four years ago and stored the Sierra at my sister's house.  A big mess was made when her fiancé passed while she was taking care of business out-of-state in late-2024, and his son pretty much mismanaged everything to do with the estate.  Even so, I was assured that my truck was safe... until it wasn't.  I found out that my truck had been scrapped about four months after the son took over everything.  There's nothing I could do; I'm 1000 miles away and it was technically abandoned property since he'd even trespassed my sister from her own house (she had no claim to it as she wasn't married, and the fiancé was the sole owner).     Anyway, today I got my second Sierra.  This is a 2010 SLE 2WB CCSB with a little over 200k miles on it.  It's got the 5.3L I'm familiar with and should handle what I need it for.  Hauling stuff that won't fit in the Transit Connect (yep, I sold out, but that's the wife's vehicle) and towing a few times a year tops.  The price seemed decent, considering how much people sell their trucks for in the Deep South: $4500.  I've seen similar trucks listed for more than double that.  I got it from a coworker who left his tag on until we transfer the title next week (Louisiana requires a notary for transfers), so I've been driving it all day.  The rear speakers don't work, which is one of the things that brought me back to these forums earlier.  I can't say how active I'll be as a poster, but I'll be scouring the archives while I find out every little thing I can about the 2010s and particular nuances/problems with my truck.   It's definitely not a GMC, but I got another Willys Jeep a few months back as well, so I'm almost at the same place I was when I first joined gm-trucks.com.  My old 1960 DJ3A was sold back around 2010 or 2011; my current Jeep is a 1946 CJ2A.  So, I've got a slightly newer GMC and a much older Jeep.  I kind of wish I still had that F-250 I had way back when too.  The Dakota is long gone and was technically my brother's truck, though I had it registered and insured.  The F-250 had to go when my grandmother's house was foreclosed on due to mismanagement around 2012 or so.     Hopefully anyone that made it this far isn't too annoyed.  I tend to be long-winded, but I'll be doing more reading than posting in the coming months.
