I can not find anything that tells what size the dash speaker is.. According to Crutchfield it's a 2.75, My question is will a 3.5 fit?
Also It says The Front doors will take a 6x9 is that with an Adapter?
Could it.... without cutting.....NO.  But I made em fit..
How difficult was cutting that open enough to fit.
Sent from my LG-G710 using Tapatalk
It was really easy with a Dremel. Bit then i made a frame for the Focal because there was about 90% of the factory mount that was moved.  You cant just trim around to make them fit.
Awesome. Thanks!
So were you able to get in down into the dash where it is seated? I'm Thinking about going with some Kicker Coaxial that are 3.5 and doing the Kicker 6x9 and the Kicker rear door also.
Yup. It took some work and not being afraid to cut. The only thing you see is the tweets on top of the grills. But I might change the mounting for them too.
How do you like the tweeter placement? I put mine (Focal too) in the door sails with the same Mounts pointing at me. I think they are too close to my ear and therfore maybe too bright. Was considering a flat mount in the same location to see if that helps, or up on dash like yours.
My tweets are facing more towards the side of the truck. I also have the jl 800/8 vxi amp so each of the 8 are individually tuned to frequency, gain, time allignment. I didnt want to to put the midrange in the door next to woofer because I wanted to hear more mids higher up front facing me. So the doors have the woofers, and the dash has the mid and tweets. Pretty much how it was with the factory Bose i ripped out. But the Bose top dash speaker is almost a full range crossed over at 400.
Edited by RACERX7775
How does the factory non Bose head unit work if you just buy better speakers? Will it sound much better then stock or not worth changing out OEM speakers?
9 hours ago, RACERX7775 said:
My tweets are facing more towards the side of the truck. I also have the jl 800/8 vxi amp so each of the 8 are individually tuned to frequency, gain, time allignment. I didnt want to to put the midrange in the door next to woofer because I wanted to hear more mids higher up front facing me. So the doors have the woofers, and the dash has the mid and tweets. Pretty much how it was with the factory Bose i ripped out. But the top dash is almost a full range crossed over at 400.
Does your setup still have factory headunit? If so, do you notice if the dash speakers still produce significant volume even when the headunit is faded all the way to the rear? I am trying to sort out if I got something hooked up reversed, or if that's just the head unit’s steering for environmental sounds reasons. I have a Nav-TV and JL HD amps. Doors and sub on one amp (4+1), dash on the other (2). I kind of wished I had looked into the Vxi amp series, for the extra control.
20180721_194326.thumb.jpg.3e2a134430496d70622c13946cddd64c.jpgYeah, i have the nav-tv piece too. $850ish.... I do have the factory head unit. There should be zero sound when you fade any position.  But I have the 800/8 and the 600/1 vxi amps with the jl hub. I ran a single optical wire from the nav-tv unit to the vxi hub. Then optical from the hub to each amp. So that way, there is no RCA cables in the truck. Then from the amps to the speaker wires at the bose amp harness. I ran extra wires up to the dash for the tweets. I also have the jl bass control knob. It has 3 controls that you can make it do.  At full left, it has fade to the front. At full right, it has fade to the rear. Then the knob is for bass control. Then the front button i tap to run to different system crossover configurations.  So its all tuned via my laptop. There are NO knobs or settings on the amps themselves. So i have every input setup to exactly what i want.
Add more content.
    RyGuy43
    RyGuy43
  • Who's Online   4 Members, 0 Anonymous, 380 Guests (See full list)
    • This is NOT impact damage nor neglect. There were previous class action lawsuits because of such paint preparation st GM manufacturing plant. Not just the Cherry Red Color. This paint is applied in three processes to obtain the desired color.  The manufacturer will cover for 36 months or 36k miles only. That rust is actually corrosion because of the paint process failure. Corrosion is covered for 100,100 miles or a certain months. However their corrosion doesn't include this type. Go figure. Clearly manufacturer knew from previous paint issues. This started 3 weeks ago out of the blue.
    • Is it time to put a piece of tape over the CEL?
    • consider doing electrical testing?  I would guess some power or ground wire/connection has a problem.   alldata.com has wiring diagrams, connector pinouts and diagnostic procedures you can use to find where the problem is.
    • can you tell if the reader is actually trying to get codes, and the pcm is reporting none, or is your reader just silently failing because it's not communicating with the pcm?
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
