Dragging front brakes
FL335i
Another usual day home from work.  1hr commute in traffic.  Stopped at Home Depot on the way home and when I parked and got out I smelled what I thought was a burning clutch of a parked car near me.  Got home in my driveway and smelled it again.  Jacked up the front end and spun both front wheels. the small was 100% coming from the front left wheel.  The wheel spun free, but had a "slight" amount more drag than the right wheel.  The moment I pulled in the drive I got my IR temp gun out.  The LF rotor was around 228F and the RF rotor was around 107F.  And you could smell it.  So the LF rotor was the source.  After dinner and a few hours I cleaned the brakes out with wheel cleaner thinking it might be mud from the job site (no mud lately).... and took it out for a spin.  Seems ok now.  I put rotors and pads on it about 3 months ago.  I went with the Akebono performance ceramic pads.  I lubed everything up including the pins with ceramic grease.  I've had no issues with the brakes until tonight.  I've put maybe 7,500 miles on them since install.  But something is going on now.  I am wondering if it's a bad hose or if the caliper is going bad.  TBD... I'm driving it to work tomorrow.
Let us know?  I was initially sold on ceramic pads long time ago and had issues every time with glazing,warping etc.   I have stayed far away from that combo.  Also, I would be using AC Delco Silicone Brake lube on pins.
I recently slapped on EBC rotors and pads front and back...and I will say they are dirtier but very impressed with the combo.....I don't fade away or Vibrate on the hills in 110f anymore.  Hope your Rotor is not warped and situation ultimately happens again 3-5 months later all because of swelled bushings and crappy slide lube.
I used the below lube for the pins and on the pad contact points. I've used it on much higher performance vehicles and never had issues. I drove to work this morning and the minute I parked i got my IR gun out and shot both rotors and calipers.  Everything is normal. 108F +/- on both. Actually the RF was a few degrees hotter than the left.  The rotor appears to have no visible damage or discoloring. I really am liking the ACDelco and Raybestos Police rotors.  I'm leaning toward it's a rubber hose or caliper that is going bad.  I may do both front hoses this weekend to rule them out... I'm at 92k.  And take everything apart and check the lubricant on the pins and verify the pads are not "tight" in their fitment. I don't want this happening again in 3 days while i'm 5hrs from home.
https://www.permatex.com/products/lubricants/specialty-lubricants-brakes/permatex-ceramic-extreme-brake-parts-lubricant-2/
I had just enough dirt and surface rust collect under the clips that caused the caliper to drag and hang up. The pad would stick and drag on the rotor enough to make a light squeal when I allowed the truck to coast or when backing out of the driveway. I bought a set of the higher end Powerstop pads and made made a point to apply copper antiseize between the caliph and the clips, as well as where the pad ends fit into the clips. I didn't notice the rotor getting hot enough to smell so it might not be the issue you had.
Hondahawkgt- That sounds like exactly the issue I had.  I'm on day 2 with no issues.  I'm starting to think the Akebono pads I put on fit tighter than the OEM pads and hence do not like the sand and dirt from my work site.
  • 4 weeks later...
Update on this.  the LR brake started dragging again this week.  Got it apart this weekend. Here is what I found and learned.
1- The purple ceramic brake grease turned to hard powder inside the slide boots.  Not sure why? Threw this stuff in the garbage and will never use again.  I picked up some Pure Silicone CRC Brand grease at Autozone ($15/tube!!) and it appears to be much better grease.  up to 3,000 degrees F.  More in line with what the factory grease looked like.
2- I should have replaced the rubber slide pin boots when I did the brake job a few months ago.  They were not torn, but while cleaning and re-greasing I ripped one.  Went to Napa and picked up a hardware kit with anti rattle pad clips and boots.  $9 for both side.  Best kit ever!!!!!
3- As included with the above hardware kit, I used the Napa pad clips.  They have a rubbery type coating to them!!!!  The Akebono clips were just plain metal.  These clips should help combat squeaks and not attract dirt by using grease.  SO happy with these Napa clips!!
4-The Akebono extreme pads I have are going to be replaced at my next oil change.  I noticed that the squeak shim that snap on the back of the pad rubs and make contact with the caliper bracket.  It's the shim arms in a few spots that go over the pad edge that are making the contact.  I can't recall, but I think the factory pads had a shim but it did not have little arms at the top/bottom of the pad.  It was glued/attached directly to the pad, which would not make any contact with the caliper bracket. Going with Raybestos Ceramics like I did on the rear or a GM/ACDelco Factory pad.  I'll verify the pads get do not have shims that "clip over" the pad.
5- I replaced the brake hose with an ACDelco unit.  $15 on Amazon.  I was right there, cheap insurance to help correct the dragging brake issue.
All in all, I think we had a few things that contributed to this issue.  I DO NOT RECOMMEND the Akebono Extreme pads for our trucks.
Took it out for a spin this afternoon...  back to dragging.   Replaced the Caliper with a NAPA unit.  Drove it for 45 minutes, fixed.  Worked my way to the more expensive part I guess... At my next oil change I'll swap the pads out to GM OEM and update the slide pin boots and rattle clips on the passenger side so my OCD is satisfied.
I bought the raybestos police rotors and their hybrid pads after reading your thread about the axles. When I did the brakes, I had to replace 3 of 4 calipers due to rust inside the pistons. Hopefully the NAPA part serves you well. Unfortunately I chose remanufactured calipers and I’m less than impressed so I’ll be upgrading them sometime in the future.
Drove it back and forth to work tonight.  Hit it with the IR Temp gun when I got home.  the LF was slightly cooler than the RF.  All good so far.  I've got about 60 miles on the new caliper....
    • Declaring victory would upset the demons that possess this Blazer, so I won't. But I did make progress today--after it put up a fight. Always a fight.   I had the day off so I spent the morning cleaning up the shop and I thought I'd get ahead of things by filling the cooling system in prep for the final part I needed to arrive: the driver's side knock sensor. Glug, glug, glug....and then the unmistakable sound of liquid hitting the shop floor. It induces the same chagrin when the sonar and targeting laser temporarily malfunction during a late night bladder evacuation over the toilet with the bathroom light off. D'OH!!! That made a mess...   Oh, hey, that knock sensor I removed? It threads into a wet port. Who knew?! Learn something new every day. Put a pin in that chore, I'll fill it the rest of the way later.   The knock sensor arrived at about 1pm. I threaded it in, connected the wire, filled up the coolant, checked for leaks, and... drumroll.... fingers crossed for a perfect start, excellent timing, model fuel trims, and ...no squeaks... Here goes.....   No, it didn't start. At all. I cranked it a few times and it wasn't sounding good. Furthermore, I heard leaking again. Jesus H Tapdancing Christ, stop leaking all over the dang floor. This time I had accidentally overfilled the coolant reservoir and the churn of the water pump via cranking caused a bit to burp out. Ok, just, breathe... Put the flamethrower down. Dang thing wouldn't burn anyway, leaks too much...   Did you know the rotation of a round crank sensor in a round hole, matters? I do now. Took me about half hour to retrace steps and realize what I had done. Then it started right up.   No squeaks. The squeak was the old balancer.   Once it entered closed loop, fuel trims are dead on, hovering right around zero at idle. No more -30%. I'll credit the injector rebuild on that one.   Timing? I think there's an OBD 1.5 translation error with my Actron scanner. It's anywhere from -20 to -30 at idle, sometimes as high as -40 cruising. Sorry, the engine just isn't running that smoothly at -40 degrees ignition advance. It's just not. It's smooth all through the rev range and has decent power. I'm going to have to trust the seat of my pants on this one.   The new exhaust is very quiet. The old catalytic converter? Not melted, but definitely not healthy. Rains glitter when you turn it on its end...all the precious metal is flaking out. Once the new exhaust system burned in/smoked off a bit, the engine's exhaust smell is normal again. Not that I'd recommend going around huffing car exhaust, but, you know what I mean?   One problem to correct. The new exhaust has the opposite problem of the old spliced up exhaust. It wants to hit the floor where the old one wanted to rest on the cross member. Happy medium, please? Still noodling on that one, need to look at how I can adjust some hangers.   I don't know what's next. On one hand I want to run away from this thing as far and as fast as I can -- there have been a lot of NOT fun moments. On the other, now that it kinda drives nice, maybe drive it around for a little bit?   Shhh... it's not currently dripping oil all over the floor. I can see just a little wet at the bottom of the timing cover where it meets the oil pan seal. It's not dripping multiple drops with every ignition cycle, in fact, after some driving this evening it has yet to even form a drop that could drip off yet. But the weekend is young... I fully expect this could turn into Exxon Valdez by Sunday. Because this Blazer hates me. LOL.
    • About that:   Once upon a time in a land far far away lived a car company that was shy about taking your money and wanted to be sure that they gave you more that you asked for so that you'd come back. No really, not a fairytale. 😱   But after the field got thinned out enough to limit the competition it seemed good enough to give you only what you asked for. Fair enough I say but in such a market you have to give something the others are not or they go to the one who does. Gimmicks or glitz. Oh, fins and chrome. Yea, shinny crow like cars. Yum.    Field narrows a bit more and 'brand loyalty' becomes a thing and the minute it does they start thinking to themselves, "Could we make more money if we gave them less than they expect and they will hang in there for brand and comfort with the known?" They gave it a try and da*n, it worked!!    Well, what if we teach them, groom them into believing that less is "Normal" and cut some more corners. Will that work? Oh heck yea!    🤔 I wonder, can we give then WAY less than they expect and make them mad enough to spit nails and STILL get them to pay up? Sure, if we get everyone else to do the same so that the choice is less or nothing at all. How would be do that? Platform sharing.  What a concept, right?  Steal like there is no tomorrow and it's legal too!    Truth is no one is going to give up driving, not for very long. The Gen Z crowd is fine with it and will be as long as someone not Gen Z will haul them around. At some point we all die.    Economic voting only works if you cast a NO vote now and again and enough of them to get dumb and dumber to wise up. Well, that's how I was taught anyway. And it should have worked. Would have worked. But the Bail out!!   Look, you have another choice if  you take that bag off your head. If the dumb it down to some predetermined expectation of how John Q Public will use it the, that is under design it to failure they you use it to a lower stress mode. D'ho!    A 1950 Royal Enfield Bullet 500 will go anywhere a Suzuki Hayabusa will and for just as long. But you will have to treat it for what it is and not for what you wish it was.
    • Maybe I was just too unlucky, but I had nothing but bad luck with Bridgestones. Out of 3 sets, they all started losing a lot of air when they got down to about 1/2 tread life, and at that point also wet traction suffered more than it should have. Also, the only tire I ever had in my 60 years of driving that had a side wall blow out was a Bridgestone.   I'm currently running Goodyear Wrangler Workhorse AT and am very happy with them.
    • maybe when the trip is over, check all the other joints in the front end, like all the ball joints, tie rods, pitman & idler arms, etc...
    • Thks, and actually it was my bad, because here in this post there is someone showing the correct wire position as well. My bad... But thank you a lot with the help as well. I was able to find and buy a 10 channel VPM that came from a sister silverado of mine. The same year, same mode, same trim, same everything. 2022 Silverado 1500 LTD LTZ (pre-refresh). I also found to buy just the bottom mirror part that has the cameras, so way cheap than the full mirror. + a used front camera. I did test everything together, cameras, cables and the VPM.... everything worked EXCEPT my original Bed camera and the backup grid lines. I think the reason is because now I need to do the VPM reprogram. I sent a msg White Automotive & Media Service to confirm that it is the problem and that they can do it service for me case.   Once I get it 100% done I will post here result....
